c++ grab in position signal
- Thank you received: 4994
23 Sep 2014 00:47 #51444
Can you confirm that the pin really does exist (using halmeter, or halcmd)
Replied by andypugh on topic c++ grab in position signal
parameter named #<_hal[mycomponent.kstop]> not defined
The following user(s) said Thank You: bkt
- bkt
- Thank you received: 113
23 Sep 2014 01:10 #51447
by bkt
Replied by bkt on topic c++ grab in position signal
yes ... now I try to force it to 1 and in hal meter and in hal configuration it exist and go to 1 value
.... mmm ... the previous version of mycomponent.comp are named MYcomponent.comp .... yesterday during my first test I see that calling hal parameter into gcode is supported only for lowercase, than i renamed MYcomponent pin and hal pin in hal file, in component and in all custom Mcode to lowercase "mycomponent". Than I cancel Mycomponent from usr/bin folder and I compiled again "mycomponent" and I install it (using sudo comp --install & sudo comp --compile ..... there are some other operation for complete the change from "MYcomponent" to "mycomponent"??
I call gcode like a subroutine using halui.mdi .... I'm on ubuntu 10.04 and linuxcnc 2.5.4 ...I do not know what else to add
23 Sep 2014 01:12 #51448
The filename and the component name declaration in the .comp file have to match exactly or you get hard-to-spot errors.
- ArcEye
- Thank you received: 758
23 Sep 2014 02:00 #51450
by ArcEye
Indeed, you need to stop using capitalisation, dashes or underscores in names also.
All of those can lead to unexpected errors, the python interpreter in comp will for instance try to subtract one half of a name from the other half if you use a dash
Replied by ArcEye on topic c++ grab in position signal
- bkt
23 Sep 2014 02:16 #51452
by bkt
normally in all my code I don't use strange caracters ..... only use number for reply some var.... in this case I have use MYcomponent... sob ... but yesterday I change all reference to this component to "mycomponent" ..... anyway have this error ..... how I can solve it? ... change name, and all other reference, of my component (example in charlie.comp , charlie.signal, etc etc) can solve this issue? ..... there are other operation to do?
23 Sep 2014 02:22 #51453
I am still not 100% clear if you can see the HAL pin "mycomponent.kstop" during normal operation.
If you can, then perhaps try executing a G-code program that tries to access it to see if that works. (maybe it is something related MDI-ing the G-code sub from other code)
Did you enable G-code access to HAL pins by setting the INI file option? (I can't recall if I ever mentioned that)
linuxcnc.org/docs/html/remap/structure.h...d_sub_ini_features_a
- bkt
23 Sep 2014 03:11 #51456
by bkt
yes during normal operations mycomponent.kstop work OK .... BuT I never read and see the doc that you have mentioned .... very thanks .... I don't understand the right mode to declare this feature...
FEATURES: 8
or
FEATURES: enable #<_hal[my component.stop]> ??
FEATURES: 8
or
23 Sep 2014 03:30 #51457
You need to make sure that your INI file has an "[RS274NGC]" section (but it is very important that there is only one)
If it isn't there, then you just need to add it.
Then puton that section (to enable both HAL and INI file parameter access)
I can only apologise that I forgot to mention that earlier.
Then put
FEATURES = 12
- bkt
23 Sep 2014 04:34 #51459
by bkt
do not worry ..... I should do more study the doc.
- bkt
23 Sep 2014 20:36 - 23 Sep 2014 21:02 #51482
by bkt
in ordet to solve my ysterday question, today have re-rename mi comp in e.comp ..... all custom Mcodes and other pins or signal become now e.xxxxx .... in mi file.ini I've add FEATURES=12 .... and I read this post
andypug-goodworck
.... but I still have the yesterday problem with the parameter # < _ hal [ e.sftop [> ... if you launch a command mdi so .... I get ######
but in hal meter I see it to change value from 0 to 1 and vice versa .......
ps. to avoid any problem I deleted every other INI files related to other tests done on the pc apart from that I work on.
.... I get ###### with FEATURES=12 and 28 too
(debug,#<_hal[e.fstop]>
(debug,#<_x>
Last edit: 23 Sep 2014 21:02 by bkt.
Time to create page: 0.127 seconds
