- Thank you received: 994
Pause function for use with a router
- rszemeti
- Visitor
11 years 4 months ago #60217
by rszemeti
Replied by rszemeti on topic Pause function for use with a router
This particular machine is a simple single head machine with a servo-driven Z axis, nothing complex. It's a retrofit after the ancient controller on it lost it's init code. EMC seemed like the best option to get the servos up and running in closed loop.
I would prefer a single-button solution as when things go wrong and you quickly need to pause the job, that's when you are going to forget the second button.
Is there a way to find out if that code linked above made it's way into 2.7? or did it work it's way into MachineKit?
- BigJohnT
11 years 4 months ago #60223
by BigJohnT
Replied by BigJohnT on topic Pause function for use with a router
- rszemeti
- Visitor
11 years 4 months ago #60225
by rszemeti
mmm .. sorry, I must be kinda dumb today.
I don't really understand how to hook up that "moveoff" thing to do what I need. I guess I can skip the GUI as I don't need that, so I'm guessing I hook this "moveoff" block up in the Z axis and trigger it to retract the Z just after the pause button is hit?
- BigJohnT
11 years 4 months ago #60227
by BigJohnT
I'm really dumb too about moveoff, I just know you can jog while paused with it and it is in version 2.7.
JT
JT
- dgarrett
- Thank you received: 297
11 years 4 months ago - 11 years 4 months ago #60231
by dgarrett
Replied by dgarrett on topic Pause function for use with a router
There are more than 8 example Sim configurations in 2.7. Each has a text file and there is an overall Readme with some instructions
See the directory:
configs/sim/axis/moveoff
More detailed instructions are at:
www.linuxcnc.org/docs/2.7/html/config/moveoff.html
Three is a manpage for the component:
www.linuxcnc.org/docs/2.7/html/man/man9/moveoff.9.html
See the directory:
Last edit: 11 years 4 months ago by dgarrett.
The following user(s) said Thank You: rszemeti
- rszemeti
- Visitor
11 years 4 months ago - 11 years 4 months ago #60235
by rszemeti
The "z_retract" example looks like it might work, one question ... if the retract distance is pre-set and you bang the pause button when the axis is already fully retracted (eg when moving between fixtures) ... what happens then? out of limits error?
what I was wondering is if there was some way to feed the pin that has the value of the retract distance with the distance the joint is currently from its zero position
so sorta
joint.2.position -> x by -1 -> feed into z retract distance pin
would that be doable and make it retract just the right amount?
so sorta
Last edit: 11 years 4 months ago by rszemeti.
Time to create page: 0.267 seconds
