Move on extents
- FiliP
03 Jul 2015 18:09 #60387
by FiliP
Replied by FiliP on topic Move on extents
So this is possible!
Big thanks ArcEye! Ill try use this on my AXIS configuration.
- ArcEye
- Thank you received: 240
03 Jul 2015 18:22 #60388
by ArcEye
Replied by ArcEye on topic Move on extents
There was something corrupt in the previous zip.
This one opens properly
- FiliP
17 Jul 2015 10:38 #60670
by FiliP
Hi.
I'v used another way to get my data.
I wrote this linuxcnc.org/index.php/english/forum/41-...es-pin-in-axis#57846 to .axisrc (removing unwanted data, Z axis)
Then i edited .INI config to get HAL pins from GCode (ENABLE = 8 at [RS274NGC] section)
linuxcnc.org/docs/html/remap/structure.h...d_sub_ini_features_a
The following user(s) said Thank You: BICHLER
- BICHLER
31 Dec 2022 07:15 - 31 Dec 2022 07:19 #260636
by BICHLER
Replied by BICHLER on topic Move on extents
this working on LinuxCNC/AXIS Version 2.9.0~pre0Simply copy to /bin/ folder rename it axis.py --> axis
make executable
make executable
Last edit: 31 Dec 2022 07:19 by BICHLER.
Time to create page: 0.932 seconds
