New Vismach Simulation Model
  • jstoquica
  • jstoquica's Avatar Topic Author
  • Premium Member
  • Premium Member
04 Aug 2015 00:44 - 05 Aug 2015 21:08 #61149 by jstoquica
New Vismach Simulation Model was created by jstoquica
Hello,
I am trying to develop a new model of 5 DOF Manipulator in vismach simulator, now I have the parts of the robotic arm in *.obj files. And I have some doubts:
1. I did the parts in millimeters, but the PUMA configuration is in inch, how I can modify the parameter? In the *.INI file, só?
2. What is the right structure code for generate a simulation interface?
3. Also the sites:
linuxcnc.org/docs/devel/html/gui/vismach.html
wiki.linuxcnc.org/cgi-bin/wiki.pl?Vismach
4. The community has any other relevant documentation or information for generate a new model in vismac?.
Thanks for your cooperation.
Last edit: 05 Aug 2015 21:08 by jstoquica.
  • jstoquica
  • Premium Member
  • Premium Member
12 Aug 2015 02:45 #61303 by jstoquica
Replied by jstoquica on topic New Vismach Simulation Model
All it's done, I did my model in vismach. Thanks.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
12 Aug 2015 14:22 #61323 by andypugh
Replied by andypugh on topic New Vismach Simulation Model
I saw this thread too late.
I recently added a manual section for Vismach.
www.linuxcnc.org/docs/2.7/html/gui/vismach.html
You might be able to add to, or correct errors in, that document.
The following user(s) said Thank You: Roguish, jstoquica
  • jstoquica
  • Premium Member
  • Premium Member
12 Aug 2015 21:24 #61358 by jstoquica
Thanks for your answer,
I want to help with detailed documentation, initially with vismach. How can I do that?
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
12 Aug 2015 23:40 #61359 by andypugh
The raw source of the document I linked to is here:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...d56eb9aa58dd0cf969f1
(and the images are in the "images" directory.)
If you click on the "raw" link next to vismach.txt then you will get the asciidoc-formatted file that creates the PDF and HTML documents.
A very brief intro to asciidoc is here:
(It is designed to be human-readable as raw source)
Make any changes you think need to be made, and attach then to a post here, if you want.
28 Feb 2022 06:43 #236015 by Raouf Magdy
Replied by Raouf Magdy on topic New Vismach Simulation Model
bro, can u help me create my vismach model?
You can contact me: Messanger: www.facebook.com/raouf.magdy.5
Whatsapp: +20 01122363077
Telegram: @RA022F
Gmail: This email address is being protected from spambots. You need JavaScript enabled to view it.
Your help is highly appreciated. Thanks.
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
28 Feb 2022 06:47 #236016 by andypugh
I suggest reading the docs and experimenting.
We can probably help with _specific_ questions. eg what an error message is really meaning.
28 Feb 2022 07:06 #236018 by Raouf Magdy
I did read it but it isn't working, I am missing a lot of things so it doesn't work so I just need a mentor to help me, that's it.
28 Feb 2022 08:58 - 28 Feb 2022 08:58 #236021 by Aciera
Replied by Aciera on topic New Vismach Simulation Model
This is a double post.
Please continue in your other thread:
forum.linuxcnc.org/38-general-linuxcnc-q...232-robot-simulation
Last edit: 28 Feb 2022 08:58 by Aciera.
