Figuring out what kind of move is being executed?
11 years 2 weeks ago #63838
Tungsten Carbide is (surprisingly, perhaps) conductive. I don't know if it is subject to oxidation, but I think that the rods (at least) of my Renishaw probe are carbide.
Replied by andypugh on topic Figuring out what kind of move is being executed?
cncbasher wrote: have you tried gold plating the balls etc , although removing the chrome may be the worst point
- DaBit
- Thank you received: 19
11 years 2 weeks ago #63846
by DaBit
No, I haven't.
Gold is not very suitable for switching contacts. For stationary contacts it is, because it tends to weld to itself under pressure and forms a gastight and excellent conducting seal that way. Once you break the contacts, you also tear a layer of gold apart. See what happens with 3.5mm headphone jacks; after 300 insertions the gold is gone.
A better material would be palladium or so. Could as well be unobtainium.
BTW: If I wanted gold plated balls and rods, I would visit the local body piercing shop. Dumbells (or whetever they call them) are available in all sorts and sizes.
voltage over the contacts is CR2032 battery voltage: 3V.
Current through the contacts is currently 15mA max, but as soon as I detect a low resistance I switch off the current for ~50usec to prolong battery life and reduce load on that 2032 coin cell. This does add a little latency on break.
On make voltage is present 100% of the time, until contact resistance is low enough. Thus, no additional latency on make.
Where do I see PM's? Didn't know we had such a feature here. Didn't receive a notification either.
You can also mail me at dabit a icecoldcomputing point com
If I ever build a v2.0, I think I would indeed use tungsten carbide. The rods are no problem (I never break an 1/8 endmill, *cough*). But this time I just happened to have 6mm steel balls and 3mm ground steel pins in the correct length.
Replied by DaBit on topic Figuring out what kind of move is being executed?
cncbasher wrote: have you tried gold plating the balls etc , although removing the chrome may be the worst point ,
No, I haven't.
how much current and voltage are you dealing with across the contacts ? i.e on a contact break & on contact make
( sent you pm )
i think we can solve this .
andypugh wrote: Tungsten Carbide is (surprisingly, perhaps) conductive. I don't know if it is subject to oxidation, but I think that the rods (at least) of my Renishaw probe are carbide.
Time to create page: 0.314 seconds
