Beginner kinemetrics setup for linear delta?
09 Mar 2016 23:47 - 10 Mar 2016 03:53 #71296 by andyhol
I am trying to get linux CNC setup to start a linear delta bot.
I have been searching, I think I have found some kinemetrics for it but I cant find anything to tell me how to setup linux cnc.
I am planning to run three steppers with stepper drives like geckos. A PC and the the PC LPT port.
I have done xyz setups like used in mills before but I am new to this kind of a setup.
If someone could point me to an example or some detailed instructions that would be great.
If you have a proven kinemetrics setup files they would be greatly appreciated also.
Thanks guys
Andy
Last edit: 10 Mar 2016 03:53 by andyhol.
10 Mar 2016 15:30 #71340 by andypugh
Replied by andypugh on topic Beginner kinemetrics setup for linear delta?
You want these files here:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...83b208ddc08d873db180
I have no idea where the files are now. They seem to have just evaporated from the LinuxCNC project.
10 Mar 2016 15:42 - 10 Mar 2016 15:57 #71343 by dgarrett
Replied by dgarrett on topic Beginner kinemetrics setup for linear delta?
lineardeltakins have always been in joints_axesNN branches as far as i know:
latest is joints_axes12
git.linuxcnc.org/gitweb?p=linuxcnc.git;a.../heads/joints_axes12
example sim configs are ldelta.ini, ldelta_demo.ini
Last edit: 10 Mar 2016 15:57 by dgarrett.
11 Mar 2016 10:44 #71385 by andypugh
Ah, that explains it.
I have never figured out how to tell which branch I am looking at in Gitweb.
Or how to tell which branch a commit was pushed to.
11 Mar 2016 15:11 - 11 Mar 2016 15:15 #71410 by dgarrett
you can go to:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a=summary
and then scroll down to the bottom where 'heads' are listed in order of activity
Last edit: 11 Mar 2016 15:15 by dgarrett.
11 Mar 2016 15:37 #71414 by andypugh
Yes, but what I mean is that once you have chosen a branch and are looking at a commit or in the tree, you can not see which branch you are in.
For example, this commit page
I don't know how to tell which branch that commit was applied to.
11 Mar 2016 16:34 - 11 Mar 2016 16:34 #71425 by dgarrett
there is something odd about the commit you reference (a04ddb857feaaf3b) because the usual
method of finding containing branches:
git branch --contains a04ddb857feaaf3b
returns nothing.
The git --contains command works for the parent commit:
git branch --contains ab4fa67b1219
and one can checkout a04ddb857 (detached head) so the commit does still exist
$ git co a04ddb857
HEAD is now at a04ddb8... Linear delta kinematics
I wonder how you got the page link?
Last edit: 11 Mar 2016 16:34 by dgarrett.
11 Mar 2016 16:41 #71429 by andypugh
An old email from Charles Steinkuhler about lineardeltakins.
But even for a less odd commit, finding the branch that the commit was applied to is rather difficult in the web interface. (Which is all I have access to at work in my breaks)
11 Mar 2016 16:57 #71432 by dgarrett
if you have access to github (github.com/LinuxCNC/linuxcnc) you might be able to use
hints from:
stackoverflow.com/questions/9360809/how-...ithub-commit-was-for
12 Mar 2016 00:50 #71459 by andyhol
Replied by andyhol on topic Beginner kinemetrics setup for linear delta?
Some of my problem was finding the files which is now taken care of, thank you.
But I have found some files in the past and was unable to determine what to do with the files, some help with this would be greatly appreciated.
First I see an .INI file, where does this need to be placed?
Second I see a .c and a .h file which I would think means compiling, if so is there some tutorial that tells me how to do this?
After this do I need to run setup again or am I just making adjustments for my system in the ini file or something.
I apologize for asking but in my earlier searches I have been unable to find answers to these questions, links pointing me in the right direction would be helpful also.
Thank you
Time to create page: 0.712 seconds
