Beginner kinemetrics setup for linear delta?
- andyhol
13 Mar 2016 02:52 #71537
by andyhol
Replied by andyhol on topic Beginner kinemetrics setup for linear delta?
I down loaded
linuxcnc.org/docs/2.7/html/getting-start...etting-linuxcnc.html
on my windows machine, checked the md5
Burned it to a DVD and it stop at detecting network hardware.
Any thoughts
Any thoughts
- andyhol
13 Mar 2016 05:26 #71540
by andyhol
Let the computer sit in the spot that I thought it was stuck for about 30-45 minutes and it finally keep going, so it is installed now. need to get the rest setup now.
- andyhol
13 Mar 2016 06:06 #71541
by andyhol
I added
deb buildbot.linuxcnc.org/ wheezy scratch-rt
deb-src buildbot.linuxcnc.org/ wheezy scratch-rt
to synaptic and when I press reload, it tells me that the source and binary are 403 forbidden.
Am I missing something?
- andyhol
13 Mar 2016 16:47 #71571
by andyhol
I get the 403 result by doing it the console way as well.
13 Mar 2016 18:54 #71574
So do I. I didn't on Friday.
I will make enquiries.
Replied by andypugh on topic Beginner kinemetrics setup for linear delta?
The following user(s) said Thank You: andyhol
- andyhol
15 Mar 2016 00:15 #71658
by andyhol
I got home from work and I was able to load scratch-rt. The simulator seems to be working, now I just need to get it hooked up to some motors; may be some research to refresh my memory on that part, it has been a while.
Thanks Guys
Thanks Guys
15 Mar 2016 00:19 #71660
You probably want to start with the ldelta rather than ldelta_demo config to connect to real hardware.
- andyhol
15 Mar 2016 03:37 #71667
by andyhol
Can I use StepConf to create the files for axis-es?
Example create a new config with stepconf called my-mill that sets all of the lpt pins, directions, speeds, etc; and then copy the .hal file to the ldelta dir and change the name?
15 Mar 2016 09:08 #71669
I don't know if Stepconf has been updated in the JA branch to create JA-format configs.
Give it a try, see what happens.
- andyhol
03 Apr 2016 23:33 #72661
by andyhol
I have finally been able to get back to this project, and I have run into errors when trying to actually hook up hardware.
I am running stepper motors with gecko drives via the lpt port. I modified the config files created by the step conf wizard but they bring up an error page and EMC wont run.
Any suggestions?
Thank You
Andy
Any suggestions?
Thank You
Andy
Time to create page: 0.233 seconds
