XHC-HB04, zero current axis from "=0" button, and axis selector
7 years 6 months ago #130997 by travis036
while i was browsing around the HAL configuration utility, i discovered that the following signals are available:
xhc-hb04.button-zero-x xhc-hb04.button-zero-y xhc-hb04.button-zero-z
when i plugged them into the watch window, and selected, say, the X axis on the jog selector, and pressed the "=0" button, it activated the xhc-hbo4.button-zero-x signal. now, how do i connect these HAL signals to zero the selected axis to the work piece when pressed? it would definitely save me some time.
BTW, running LinuxCNC 2.7.? (disk distro)
if it helps, i have uploaded my most recent configuration files (my my-mill folder contents, minus images), to my GitHub: github.com/travisfarmer/my-linuxcnc-conf
~Travis
7 years 6 months ago #131002 by Todd Zuercher
I think I would connect that to a series of halui MDI commands, that issue the appropriate G10L20 command.
7 years 6 months ago #131005 by travis036
thanks for the response.
please forgive my ignorance, but i am still learning the workings of HAL.
i will give that a try and see if it responds as i intend.
~Travis
7 years 6 months ago #131010 by travis036
from my my-mill.ini.
[HALUI] # add halui MDI commands here (max 64) MDI_COMMAND = "G10 L20 P0" MDI_COMMAND = "G10 L20 P1" MDI_COMMAND = "G10 L20 P2" [XHC_HB04_BUTTONS] ... zero-x = "halui.mdi-command-00" zero-y = "halui.mdi-command-01" zero-z = "halui.mdi-command-02"
my full config files are on the GitHub previously mentioned.
but what i have does not seem to work. for that matter, just entering "G10 L20 P0" into the MDI panel has no effect. something i am doing is wrong. HAL does read the pin associated with the button, as i have tested it with the HAL watch.
~Travis
7 years 6 months ago #131011 by travis036
did a little research on Gcode. pardon me while i remove my head from my... rear.
[HALUI] # add halui MDI commands here (max 64) MDI_COMMAND = "G10 L20 P1 X0" MDI_COMMAND = "G10 L20 P1 Y0" MDI_COMMAND = "G10 L20 P1 Z0"
are these correct?
i will have to try them tomorrow after work.
~Travis
7 years 6 months ago #131031 by Todd Zuercher
Time to create page: 0.287 seconds
