- Configuring LinuxCNC
- Advanced Configuration
- XHC-HB04, zero current axis from "=0" button, and axis selector
- Thank you received: 1482
20 Apr 2019 15:47 #131329
Replied by Todd Zuercher on topic XHC-HB04, zero current axis from "=0" button, and axis selector
No P0 just applies to whatever coordinate system is currently active. So if G54 is active it is applied same as using P1. But if G57 is active it would be the same as using P4. Because it is variably applied dependent on the current coordinate system, it might be useful for a button command like you are setting up. It lets you set any coordinate system offset rather than just one.
The following user(s) said Thank You: travis036
- travis036
- Thank you received: 32
20 Apr 2019 16:11 #131330
by travis036
Replied by travis036 on topic XHC-HB04, zero current axis from "=0" button, and axis selector
interesting, that could prove very useful. Thanks!
~Travis
~Travis
Time to create page: 1.154 seconds
