- Configuring LinuxCNC
- Advanced Configuration
- Tool table in CAM, LinuxCNC & pockets in a non-random tool changer
- bevins
- Thank you received: 338
08 May 2019 08:46 #133138
by bevins
Replied by bevins on topic Tool table in CAM, LinuxCNC & pockets in a non-random tool changer
Another issue with non-random toolchanger is if you have more tools than pockets, for example: 3 pockets 6 tools, the tool table pocket field is unique in that you cannot have two pocket numbers the same. So if you have tool 4 in pocket 4 tool 5 in pocket 5 and if you want to use one of them you have to change pocket in tool table before your tool changer will work. The tool table pocket field should not be unique. Multiple tools with same pocket is a valid scenario.
- mydani
- Banned
- Thank you received: 9
08 May 2019 08:59 - 08 May 2019 09:03 #133141
by mydani
Replied by mydani on topic Tool table in CAM, LinuxCNC & pockets in a non-random tool changer
I have to say I disagree.
Example:
Tool 17 was in pocket 3 and actually loaded in spindle.
Tool 5 is in pocket 9.
M6 T5 is called.
Algo is like this:
--> search t17 in tool table, get pocket no 3
--> tool changer is moved to pocket 3
--> tool 17 is unloaded
--> search T5 in tool table, get pocket no 9
--> tool changer is moved to pocket 9
--> tool 5 is loaded
- My tool changer needs to put the tool in the same pocket again from which it was loaded (!random)
- My tool changer has 9 pocket, ID 1 to 9, which I fill manually with tools, tool IDs between 1 and 50
- Therefore a pocket btw. 1-9 shall only be used once in the tool table, because physically there cannot be 2 tools in 1 pocket
- Exception for me: pocket 0 means not in the tool changer at all.
Example:
M6 T5 is called.
Algo is like this:
Last edit: 08 May 2019 09:03 by mydani.
- bevins
08 May 2019 09:14 #133143
by bevins
That is a random toolchanger. Pockets in random toolchanger and non-random toolchanger are handled differently.
Example:
M6 T5 is called.
Algo is like this:
- mydani
- Banned
08 May 2019 10:54 - 08 May 2019 10:54 #133160
by mydani
This is what the
documentation says
"RANDOM_TOOLCHANGER = 1 - This is for machines that cannot place the tool back into the pocket it came from. For example, machines that exchange the tool in the active pocket with the tool in the spindle."
My tool changer can and must place the tool back into the pocket it came from.
So I think I am right by saying, as per this documentation, I do not have a random toolchanger.
Last edit: 08 May 2019 10:54 by mydani.
- bevins
08 May 2019 12:30 #133174
by bevins
Yeah that's a non-random. I misunderstood your explanation.
This is what the documentation says :
- bevins
08 May 2019 12:43 #133176
by bevins
So your manually changing the pockets in the tool table when you add a tool that does not have a pocket that equals the tool number.
I don't see any other way around it. Thats why if you could have same pocket #'s for different tools, then you could handle that in the remap code and only have to just swap out tools out of the magazine and not have to deal wioth the tool table. Thats all I was saying.
Example:
M6 T5 is called.
Algo is like this:
- Thank you received: 4658
09 May 2019 12:41 #133258
Replied by andypugh on topic Tool table in CAM, LinuxCNC & pockets in a non-random tool changer
One way round the more-tools-than-pockets thing is to do something clever with the pocket numbers in your tool changer HAL or remap.
If you have 4 tools that you put in pocket 5, then put them in the tool table in pockets 5, 15, 25.
Then, simply pass T-number MOD 10 to whatever drives the tool changer logic.
Though I agree that neither tool number or pocket number should have to be unique. (though most databases need some unique key, so even the database schema I came up with had such an identifier:
wiki.linuxcnc.org/cgi-bin/wiki.pl?ToolDatabase
In that case you would switch tool "sets" by changing the active "magazine"
- mydani
- Banned
09 May 2019 12:46 #133260
by mydani
I understand the workarounds, but those are still workarounds with some caveats. I guess u know this.
Guess the uniqueness thing is a matter of taste - coming from some decades of development, a tool and a pocket is a physically existing unique thing, and therefore - imho - should be represented only once also within the SW. I understand that the experiences or limitations of the current implementation leads to the wish to have it otherwise.
I will stick my nose in the code some more and change the interpreter accordingly...
Cheers
Daniel
Cheers
Daniel
- bevins
09 May 2019 13:21 #133265
by bevins
Is your DB interface working? Can I query it, write to a record and read a field within python during a remap?
09 May 2019 13:38 #133270
In a word, "No"
I didn't manage to persuade anyoen else to even try the experimental branch, so it has been fallow for several years.
github.com/LinuxCNC/linuxcnc/commits/andypugh/tooltable
Look for commits around July 2013 for the files that were changed.
Looking back at it I think that there might be a sample config, but not a lot of docs. (any, in fact)
That version attempts to have a user-editable python interface interacting with a usr-defined tool database.
I don't think any of the samples there actually use the proposed schema.
In a word, "No"
Time to create page: 0.766 seconds
