Error after CLOSING linuxcnc
7 years 2 months ago - 7 years 2 months ago #141500 by jazzuri
in addition to the above, there are the following notes because of gantry..
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.9.0-pre0-373-gb0b2758 Machine configuration directory is '/home/mdrives/linuxcnc/configs/BVR' Machine configuration file is 'BVR.ini' INIFILE=/home/mdrives/linuxcnc/configs/BVR/BVR.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI= DISPLAY=axis COORDINATES=X Y Y Z KINEMATICS=trivkins coordinates=xyyz Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Found file(REL): ./BVR.hal Found file(REL): ./custom.hal Starting TASK program: milltask Starting DISPLAY program: axis [color=red]Warning: Forward kinematics must handle duplicate coordinate letters:yy Note: Individual axis homing is not currently supported for KINEMATICS_IDENTITY with duplicate axis letter <Y>[/color] Shutting down and cleaning up LinuxCNC... task: 664 cycles, min=0.000018, max=0.015740, avg=0.009890, 0 latency excursions (> 10x expected cycle time of 0.010000s) Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments
maybe that's it.
Last edit: 7 years 2 months ago by jazzuri.
7 years 2 months ago #141501 by jazzuri
tommylight wrote: Thank you.
Did you compile Linuxcnc, or just chnged the repository and installed using apt-get or synaptics ?
just changed the repository and apt-get update/install linuxcnc.
7 years 2 months ago #141503 by tommylight
At the
Line there should be something else added containing the word "BOTH", can not recall exactly what and i am not near computers.
7 years 2 months ago #141506 by jazzuri
tommylight wrote: At the
all right, there is a line "kinstype=BOTH" in .ini file
7 years 2 months ago #141536 by rodw
Replied by rodw on topic Error after CLOSING linuxcnc
I think this is a recently introduced known bug. Just ignore it for now.
7 years 2 months ago #141540 by tommylight
Yup, i get that with the 373 version of 2.9.
Unfortunately i have no time to further investigate for now, sorry.
Time to create page: 0.082 seconds
