Challenges Tuning Servos on Brother TC-225 Retrofit
6 years 3 months ago - 6 years 3 months ago #175192 by Type_Zero_Design
Quick update.
Param 7 is set to 300
Param 15 is set to 0 (off)
Attached a screenshot of the same joint0 with the change to the HAL to run open loop.
Adjusted p=1000 and left FF1=1
been reading the Chinese/english manual today and there is a section about tunning the drive. If based on the scope you think it should be tunned better itself.. what exactly am I shooting for on the scope?
**Not sure why it keeps rotating my photos when they post. Sorry. **
Last edit: 6 years 3 months ago by Type_Zero_Design.
6 years 3 months ago #175197 by PCW
Can you also plot the commanded and actual positions?
An error plot by itself is a bit hard to interpret
6 years 3 months ago #175249 by Type_Zero_Design
Quick note... I realized on the open loop scope I posted earlier I'm pretty sure FF1 was set at 0 so may want to ignore that.
Reran the open loop jog with the requested data points P=1000 FF1=1
Below is a Closed Loop jog with the requested data points and P=8 and FF1=1
6 years 3 months ago #175439 by Type_Zero_Design
Any insight on the results above? Is this an accel decel issue?
6 years 3 months ago #176366 by rmu
I wonder what kind of drive / servo system you are using? The english in the manual is hilarious.
Your halscope pictures are bit hard to read, I would try to create actual screenshots on the linuxcnc computer, and use proper scale on all channels (nothing to see on position command and feedback because zoomed out too much).
6 years 3 months ago #176377 by tommylight
The last picture looks like way to much lag or to loose of P term and/or incorrect FF1.
"Take screenshot" should be somewhere in the menu, most probably in the "accessories"
Time to create page: 0.082 seconds
