Nutating head kinematics
- danilom
- Thank you received: 5
08 Nov 2019 01:16 - 08 Nov 2019 01:16 #149907
by danilom
Nutating head kinematics was created by danilom
Ok I really searched for the correct therm for this 5 axis configuration but only found that its called NUTATING head.
So its CA head , C is rotating around Z at an offset and A is tilted less than 45 degrees (we need to measure this angle)
Any suggestions where to start with kinematics?
Its something like this
Last edit: 08 Nov 2019 01:16 by danilom.
- Thank you received: 4658
08 Nov 2019 07:09 #149915
Replied by andypugh on topic Nutating head kinematics
How good is your 3D trigonometry? It seems that it shouldn't be too hard to calculate the tilted axis direction, then calculate the tool direction from that. The main choice would be about choosing a coordinate system reprentation you are comfortable with (spherical coordinates, direction cosines, vectors) and then deciding how to manipulate the numbers (sine / cosine geometry, rotation vectors...)
- Yannis
16 Nov 2019 03:47 - 16 Nov 2019 03:48 #150459
by Yannis
Replied by Yannis on topic Nutating head kinematics
Hi
i just finished my new B,C axis head and i m trying to edit a post processor
where can i find info(for trigonometry) to do that
is there something like user guide
thanks
thanks
Last edit: 16 Nov 2019 03:48 by Yannis.
16 Nov 2019 04:49 #150464
Which CAM system? You might be better asking on the dedicated forums.
- Yannis
16 Nov 2019 06:04 #150467
by Yannis
Alphacam and the re seller ask me a price for the post processor out of my budget
17 Nov 2019 15:25 #150548
I suspect that if the Alphacam post-processor isn't documented by AlphaCAM then you will have to work it out by inspecting the existing post-processor code.
Perhaps you need to use something other than Alphacam?
- Yannis
18 Nov 2019 01:01 #150569
by Yannis
Any suggestions?
- danilom
18 Nov 2019 02:42 #150571
by danilom
Replied by danilom on topic Nutating head kinematics
Maybe Fusion 360?
- Yannis
18 Nov 2019 23:42 #150609
by Yannis
Thanks i will check it
- danilom
27 Nov 2019 06:35 #151342
by danilom
Time to create page: 0.094 seconds
