Nutating head kinematics
28 Nov 2019 00:18 #151406 by Yannis
Replied by Yannis on topic Nutating head kinematics
I think that the head joint of this type is called cardanic head
www.google.gr/url?sa=i&rct=j&q=&esrc=s&s...ust=1575006942281400
To find the offsets is relative easy procedure with simple moves. When you find them you have to put in the post some trigonometric calculations
That part is the difficult part for me
02 Dec 2019 09:39 #151759 by andypugh
Replied by andypugh on topic Nutating head kinematics
If you had a touch-probe then I think you could derive the required measurements by Z-probing a series of C-axis circles for various (A/B) axis positions.
02 Dec 2019 09:39 #151760 by andypugh
If you had a touch-probe then I think you could derive the required measurements by Z-probing a series of C-axis circles for various ( A/B ) axis positions.
17 Dec 2019 03:09 #152783 by Yannis
I have this question witch is more trigonometry than linuxcnc
any help is highly appreciated
In a 5 axis head -head cnc with C,B and Z axis on the head of the machine the
Z axis is depended by the B axis rotation
the calculation formula to find correct Z value is =offset of B by the Z axis multiply by the sin of b angle
in my case Z[-(412*SIN(ANGLE_B))]
When i try a test program a p/2 of a cycle i have correct Z position in the beginning and the end of the path
but the trajectory of the tool is linear (not circular as expected)
Suggestions?
Time to create page: 0.556 seconds
