Nutating head kinematics
08 Nov 2019 01:16 - 08 Nov 2019 01:16 #149907 by danilom
Nutating head kinematics was created by danilom
Ok I really searched for the correct therm for this 5 axis configuration but only found that its called NUTATING head.
So its CA head , C is rotating around Z at an offset and A is tilted less than 45 degrees (we need to measure this angle)
Any suggestions where to start with kinematics?
Its something like this
Last edit: 08 Nov 2019 01:16 by danilom.
08 Nov 2019 07:09 #149915 by andypugh
Replied by andypugh on topic Nutating head kinematics
How good is your 3D trigonometry? It seems that it shouldn't be too hard to calculate the tilted axis direction, then calculate the tool direction from that. The main choice would be about choosing a coordinate system reprentation you are comfortable with (spherical coordinates, direction cosines, vectors) and then deciding how to manipulate the numbers (sine / cosine geometry, rotation vectors...)
16 Nov 2019 03:47 - 16 Nov 2019 03:48 #150459 by Yannis
Replied by Yannis on topic Nutating head kinematics
Hi
i just finished my new B,C axis head and i m trying to edit a post processor
where can i find info(for trigonometry) to do that
is there something like user guide
thanks
File Name: BCAXISHEAD-2.dxf
File Size:1,145 KB
Last edit: 16 Nov 2019 03:48 by Yannis.
16 Nov 2019 04:49 #150464 by andypugh
Which CAM system? You might be better asking on the dedicated forums.
16 Nov 2019 06:04 #150467 by Yannis
Alphacam and the re seller ask me a price for the post processor out of my budget
17 Nov 2019 15:25 #150548 by andypugh
I suspect that if the Alphacam post-processor isn't documented by AlphaCAM then you will have to work it out by inspecting the existing post-processor code.
Perhaps you need to use something other than Alphacam?
18 Nov 2019 01:01 #150569 by Yannis
Any suggestions?
18 Nov 2019 02:42 #150571 by danilom
Replied by danilom on topic Nutating head kinematics
Maybe Fusion 360?
18 Nov 2019 23:42 #150609 by Yannis
Thanks i will check it
27 Nov 2019 06:35 #151342 by danilom
This is the picture of real head, friend and I are close to finding the right calculations, after that I will measure the rotational offset and the incline angle of the head as its not exactly 45 degrees
Time to create page: 0.255 seconds
