Best practice for implementing toolchanger?
04 Dec 2019 10:03 #152003 by ross_dev
Hi
I have been reading around the documentation and forum posts for the recommended software approach to handling toolchangers. I have come across a few methods - using a hal component, either custom or modifying hal_manualtoolchange, using classicladder in some way, or (the method I have read the most about so far) using a remapped gcode and embedded python.
I understand the latter was recently added to linuxcnc, so for this reason is it the recommended path to go down? I assume pins are then mapped via the HAL.
On the hardware side I believe we are looking into using the Mesa 7i94's GPIO pins.
Cheers
Ross
04 Dec 2019 14:20 - 04 Dec 2019 14:30 #152019 by HueyHQ
Replied by HueyHQ on topic Best practice for implementing toolchanger?
Personally, I think the remap Gcode is the easiest to implement.
I looked at Python, and seemed overly complex for what I was hoping to achieve. A remap allowed me to easily read inputs, turn outputs on and off, delays - everything I needed for toolchange.
I have an example file at #146783 . (I thought I had written a post explaining the whole implementation, but I can' seem to find it, sorry.)
EDIT: I knew I'd written something - it's at post #137246
Last edit: 04 Dec 2019 14:30 by HueyHQ. Reason: Found reference post
The following user(s) said Thank You: ross_dev
05 Dec 2019 08:15 #152066 by andypugh
Replied by andypugh on topic Best practice for implementing toolchanger?
Remapping M6 to call a G-code subroutine would be my recommendation.
See the sample config sim/axis/vismcach/vmc-toolchange for a virtual machine demo config and a set of sample config files.
11 Dec 2019 07:10 #152480 by ross_dev
Replied by ross_dev on topic Best practice for implementing toolchanger?
Thanks guys, this is coming along nicely now. The remapping is really quite nifty!
Time to create page: 0.183 seconds
