- Configuring LinuxCNC
- Advanced Configuration
- [Solved] Compile Error when using regular math functions in kinematics file
- Thank you received: 2177
When I try to build it I get this error:
Linking genserkins
/usr/bin/ld: objects/emc/kinematics/genserfuncs.o: undefined reference to symbol 'acos@@GLIBC_2.0'
//lib/i386-linux-gnu/libm.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
emc/kinematics/Submakefile:18: recipe for target '../bin/genserkins' failed
make: *** [../bin/genserkins] Error 1Apparently its a problem with a missing library that needs to be added to the make file. The section for this kinematic file looks like this but I have really not much clue as to what would need to be added.
genser-switchkins-objs := emc/kinematics/genser-switchkins.o
genser-switchkins-objs += emc/kinematics/genserfuncs.o
genser-switchkins-objs += libnml/posemath/gomath.o
genser-switchkins-objs += libnml/posemath/sincos.o $(MATHSTUB)
genser-switchkins-objs += emc/kinematics/kins_util.o
I would appreciate some guidance as to solve this.
- dgarrett
- Thank you received: 297
$ linuxcnc_infoPlease Log in or Create an account to join the conversation.
- dgarrett
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.9.189-3+deb9u2 (2019-11-11)
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.9.0-11-rt-686-pae ...
gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516I cannot reproduce on a similar 64bit stretch virtual machine
but need more information.
1) Are you modifying the primary in-tree Makefile (e.g. src/Makefile)?
or
2) Are you using an independent Makefile?
In either case, please explain in more detail and post:
a)the Makefile used to produce the error message posted at
message 158554
b)the exact directory location of the Makefile
c)the source file(s) using added math functions.
Note: you have both a git tree and a deb install for linuxcnc
and that can lead to hard-to-find errors.
So I have uninstalled the deb in the synaptic manager and deleted all the RIP installations.
Then :
$ git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
$ cd linuxcnc-dev/src
$ ./autogen.sh
$ ./configure --with-realtime=uspace
Returning the message to continue to compile by typing make ....
$ make && sudo make setuid
Build fails:
I tried this a couple of times but I can't build LinuxCNC anymore.
Now I'll try an iso.
Turns out that works just fine!
I've made changes to these two files adding a third kinematics case in genser-switchkins.c which corresponds to a remap to M430. This seems to work.
Of course the difficult part is the actual code for the "gensertoolKinematicsInverse" function. Because I'm having a hard time making sense of all the pointers and go_math functions in the original code I'm trying to use a code by Rudy du Preez that should actually be able to do the toolcoordinate kinematics I want. So I copied that in. Since his code does not define any other includes I thought that would work. But when I rebuild I get the error:
user@user-iMac:~/linuxcnc-dev/src$ make && sudo make setuid
Reading 194/194 dependency files
Done reading dependencies
Reading 215/215 realtime dependency files
Done reading realtime dependencies
Linking genserkins
/usr/bin/ld: objects/emc/kinematics/genserfuncs.o: undefined reference to symbol 'sincos@@GLIBC_2.2.5'
//lib/x86_64-linux-gnu/libm.so.6: error adding symbols: DSO missing from command line
make: *** [../bin/genserkins] Error 1Probably totally obvious to other people who actually know what they're doing but I'm stumped.
All hints are welcome.
If your code includes mathematical functions (like exp, cos, etc.), you need to link to the mathematics library libm.so. This is done, just like for serial compiling, by adding -lm to the end of your compile command, that is,
mpicc -o sample sample.c -lm
But where would I add that "-lm"?
