- Configuring LinuxCNC
- Advanced Configuration
- [Solved] Compile Error when using regular math functions in kinematics file
- dgarrett
- Thank you received: 297
27 Feb 2020 10:53 - 27 Feb 2020 11:06 #158652
by dgarrett
Replied by dgarrett on topic Compile Error when using regular math functions in kinematics file
thanks for posting your source files with these i could
reproduce the DSO error, the problem is in the make for
the *userspace* bin/genserkins when using math functions not
provided by gomath,posemath etc.
Note: the bin/genserkins utility is undocumented and is likely seldom
used. it is buggy in all branches -- this doesn't effect realtime
modules using genser*.c files
force pushed dgarr/s_kins commit: 9af319596
(adds -lm in src/emc/Submakefile)
Note: the master branch is currently broken but
dgarr/s_kins is rebased to an older (working)
master branch
master branch
Last edit: 27 Feb 2020 11:06 by dgarrett. Reason: clarify note on bin/genserkins
- Thank you received: 2177
28 Feb 2020 02:52 - 28 Feb 2020 02:52 #158735
Replied by Aciera on topic Compile Error when using regular math functions in kinematics file
Thanks again for the prompt reply!
I build the newest commit but I'm still having the same issue after copying my config to the configs folder and the .c files to src/emc/kinematics:
I'm sorry to keep bothering you.
Warning: Spoiler!
user@user-iMac:~/linuxcnc-dev/src$ git branch | grep \*
* dgarr/s_kins
user@user-iMac:~/linuxcnc-dev/src$ git log --oneline -1
9af319596 (HEAD -> dgarr/s_kins, origin/dgarr/s_kins) switchkins: xyz[ab]c-trt,genser
user@user-iMac:~/linuxcnc-dev/src$ make && sudo make setuid
Reading 194/194 dependency files
Done reading dependencies
Reading 215/215 realtime dependency files
Done reading realtime dependencies
emc/Submakefile:Linking genserkins
/usr/bin/ld: objects/emc/kinematics/genserfuncs.o: undefined reference to symbol 'acos@@GLIBC_2.2.5'
/lib/x86_64-linux-gnu/libm.so.6: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
emc/kinematics/Submakefile:18: recipe for target '../bin/genserkins' failed
make: *** [../bin/genserkins] Error 1
* dgarr/s_kins
Last edit: 28 Feb 2020 02:52 by Aciera. Reason: typo
- dgarrett
28 Feb 2020 07:18 #158750
by dgarrett
and they work for me so i have pushed a
'scratch' branch that you can try:
dgarr/aciera.0
github.com/LinuxCNC/linuxcnc/commits/dgarr/aciera.0
Please test.
If this works for you, i will modify dgarr/s_kins
to make it simpler for you to add an additional
kinematics method within dgarr/s_kins.
I tested with your files on buster and stretchstill having the same issue after copying
dgarr/aciera.0
Please test.
- dgarrett
28 Feb 2020 09:55 - 28 Feb 2020 22:05 #158757
by dgarrett
28feb20 dgarr/s_kins branch update (e10cc60d371):
28feb20 later: (eed4edd7e)
1) In genser-switchkins.c, support:
motion.switchkins-type == 2
2) provide template file named switchtype2funcs.c
demonstrating functions:
switchtype2KinematicsForward()
switchtype2KinematicsInverse()
3) demonstate usage in puma560-switchkins.ini
A user can now modify just one file (switchtype2funcs.c)
to add any code necessary to provide kinematics for
motion.switchkins-type==2
It is intended that user should not need to modify any
other files in order to maintain a common and stable
genserkins base. Bug fixes for genserkins should be
implemented in appropriate in-tree files.
Notes:
In the future, the switchtype2funcs.c template may be
used with other switchable kinematics modules (e.g.,
not limited to genser-switchkins).
Template Ref: github.com/LinuxCNC/linuxcnc/blob/dgarr/...s/switchtype2funcs.c
Notes:
switchkins-type==0 is default at startup
switchkins-type==1 is reserved (and used by existing
switchable kinematics modules)
switchkins-type==2 is supported but implemented only
by a template that user can modify
as requiredIn the future, the switchtype2funcs.c template may be
Last edit: 28 Feb 2020 22:05 by dgarrett. Reason: subsequent commit noted
The following user(s) said Thank You: tommylight, Aciera
28 Feb 2020 11:03 - 28 Feb 2020 11:04 #158766
Thank you for your ongoing support!
Sadly it's not working for me on my linux mint machine:
I will setup a new machine tomorrow using debian buster and try again.
Warning: Spoiler!
user@user-iMac:~/linuxcnc-dev-aciera/src$ git branch | grep \*
* dgarr/aciera.0
user@user-iMac:~/linuxcnc-dev-aciera/src$ git log --oneline -1
6535887ec (HEAD -> dgarr/aciera.0, origin/dgarr/aciera.0) aciera.0 test 28feb20
user@user-iMac:~/linuxcnc-dev-aciera/src$ make && sudo make setuid
Compiling emc/kinematics/genserfuncs.c
emc/kinematics/genserfuncs.c: In function ‘gensertoolKinematicsInverse’:
emc/kinematics/genserfuncs.c:649:32: warning: variable ‘s3’ set but not used [-Wunused-but-set-variable]
double c1, s1, c2, s2, c3, s3, c4, s4, c5, s5, c23, s23;
emc/kinematics/genserfuncs.c:649:28: warning: variable ‘c3’ set but not used [-Wunused-but-set-variable]
emc/kinematics/genserfuncs.c:647:32: warning: variable ‘vz’ set but not used [-Wunused-but-set-variable]
double ux, uy, uz, vx, vy, vz, wx, wy, wz, px, py, pz;
emc/kinematics/genserfuncs.c:647:28: warning: variable ‘vy’ set but not used [-Wunused-but-set-variable]
emc/kinematics/genserfuncs.c:647:24: warning: variable ‘vx’ set but not used [-Wunused-but-set-variable]
* dgarr/aciera.0
Last edit: 28 Feb 2020 11:04 by Aciera.
- dgarrett
28 Feb 2020 12:45 - 28 Feb 2020 14:23 #158777
by dgarrett
i found a mint18 virtual machine and was able to
replicate your result -- not a linker expert but
a minor reordering fixed for me on that machine.
Please try new branch: dgarr/aciera.1
and report (and include output from linuxcnc_info)
Supporting&testing every possible
distribution/architecture/kernel/release
is not always simple.
Last edit: 28 Feb 2020 14:23 by dgarrett.
Time to create page: 0.726 seconds
