Non-circular boring. (Linuxcnc fun)
09 Mar 2020 20:14 - 09 Mar 2020 20:14 #159619 by skunkworks
Non-circular boring. (Linuxcnc fun) was created by skunkworks
made a surprisingly simple hal component that takes the spindle position and converts to x/y motion to create a polygon.
Last edit: 09 Mar 2020 20:14 by skunkworks.
The following user(s) said Thank You: phillc54, joekline9, chimeno, pkasy, tommylight, tivoi, COFHAL, smc.collins
09 Mar 2020 23:02 #159632 by cmorley
Replied by cmorley on topic Non-circular boring. (Linuxcnc fun)
I think you should add some docs to linuxcnc to show some of this crazy stuff you try.
Pretty damn cool!
  • Moderator
  • Moderator
10 Mar 2020 08:29 #159651 by tommylight
Replied by tommylight on topic Non-circular boring. (Linuxcnc fun)
I agree with Cmorley ! :)
Very nice, indeed.
10 Mar 2020 11:26 #159670 by skunkworks
Replied by skunkworks on topic Non-circular boring. (Linuxcnc fun)
here is me fiddling with the parameters.. (no tool offset applied)
10 Mar 2020 21:38 - 10 Mar 2020 21:39 #159741 by skunkworks
Painfully slow bore.. (ran it a bit slow)
Last edit: 10 Mar 2020 21:39 by skunkworks.
The following user(s) said Thank You: smc.collins
10 Mar 2020 22:04 #159745 by skunkworks
Really really messy - does a spindle encoder index enable and such. Some comments.
//   This is a component for Linuxcnc HAL
//   Copyright 2020 Sam Sokolik <samcoinc@gmail.com>
//   This program is free software; you can redistribute it and/or modify
//   it under the terms of the GNU General Public License as published by
//   the Free Software Foundation; either version 2 of the License, or
//   (at your option) any later version.
//   This program is distributed in the hope that it will be useful,
//   but WITHOUT ANY WARRANTY; without even the implied warranty of
//   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
//   GNU General Public License for more details.
//   You should have received a copy of the GNU General Public License
//   along with this program; if not, write to the Free Software
//   Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA.
component polygon "Create a spindle synced motion that carves a polygon using eoffset inputs.  Assumes positive rotation.";
pin in bit enable;
pin in unsigned numsides=3 "Number of sides in the polygon";
pin in float inscribedradius=1 "inscribed radius of the polygon";
pin in float cutterdiam "cutter diameter";
pin in float eoffsetscale "scale that eoffset is set to.";
pin in float toolang "angle difference between index and actual tool poition";
pin in float spindlepos "Spindle position scaled to 1 per rev";
pin out float spindlerad "Spindle postion in radians";
pin out float polyradius "radious of the polygon at given spindle position";
pin out float xoffset "x offset to send to offset componant";
pin out float yoffset "y offset to send to the offset componant";
pin out signed xeoffset "x eoffset output";
pin out signed yeoffset "y eoffset output";
pin out bit isindex "set index enable only once";
pin io bit indexenable "hooked to index enable of encoder";
function _;
license "GPL";
#include <rtapi_math.h>
#define PI 3.14159265358979323846
float spinang;
float scale;
float spinangoffset;
    if (!enable) {
        xoffset=0;
        yoffset=0;
        xeoffset=0;
        yeoffset=0;
        isindex = false;
        return;
// only set index enable once
    if (enable && !isindex) {
    isindex = true;
    indexenable = true;
        return;
// wait for spindle index before actually enabling
    if (enable && isindex && indexenable){
        return;
//convert spinangoffset to ratio.. for adding to spindle pos - plus a couple rotations
//so the spindle position isn't negative
spinangoffset = (toolang/360)+2;
//formual I found is for circumscribed - convert to inscribed - makes more sense.
scale=inscribedradius/cos(PI/numsides);
spinang = ((spindlepos + spinangoffset) - (int)(spindlepos + spinangoffset))*2*PI;
polyradius = (cos(PI/numsides)/cos((fmod(spinang, (2*PI/numsides))-PI/numsides)))*scale-cutterdiam/2;
//actual offsets applied - could be used for offset componant.
xoffset = cos(spinang)*polyradius * -1;
yoffset = sin(spinang)*polyradius;
//counts for use with eoffset functionality
xeoffset = xoffset / eoffsetscale;
yeoffset = yoffset / eoffsetscale;
spindlerad = spinang;
The following user(s) said Thank You: chimeno, snoozer77
11 Mar 2020 21:18 #159836 by skunkworks
Rotatable polygon.. 12 point anyone? (2 hexes one rotated 30 degrees)
pin in bit enable;
pin in float polyang "angle of the polygon";
function _;
license "GPL";
float spinang;
float scale;
float polyangoffset;
    if (!enable) {
        xoffset=0;
        yoffset=0;
        xeoffset=0;
        yeoffset=0;
        isindex = false;
        return;
	isindex = true;
	indexenable = true;
        return;
        return;
spinangoffset = (toolang/360-polyang/360)+2;
polyangoffset = (polyang/360)*2*PI;
xoffset = cos(spinang+polyangoffset)*polyradius * -1;
yoffset = sin(spinang+polyangoffset)*polyradius;
The following user(s) said Thank You: joekline9, chimeno, tommylight, snoozer77, Cynas, Dorro1971, smc.collins
12 Mar 2020 03:49 #159855 by cmorley
very cool.
Gonna try aluminum next? I dare you lol
Sanvik capto tool holders use a tapered polygon for connectons....
14 Mar 2020 18:36 #160235 by skunkworks
now you can attach the radius to the x axis.. - create a profile.. (this is a radius into a taper..) You can see the resolution of the spindle encoder
The following user(s) said Thank You: cmorley, phillc54, joekline9, Diederik, tommylight, smc.collins
  • Moderator
  • Moderator
14 Mar 2020 20:35 #160244 by tommylight
Awesome !
Time to create page: 0.123 seconds
