Non-circular boring. (Linuxcnc fun)
28 Apr 2020 00:04 #165882 by skunkworks
Replied by skunkworks on topic Non-circular boring. (Linuxcnc fun)
Just a little... :)
Encoder is a bit better.........
Ya think ? :)
29 Apr 2020 02:53 - 29 Apr 2020 02:53 #166052 by skunkworks
Just to see?
Last edit: 29 Apr 2020 02:53 by skunkworks.
The following user(s) said Thank You: phillc54, joekline9, tommylight, Clive S, giz, johnmc1, COFHAL
30 Apr 2020 14:05 #166218 by alkabal
Replied by alkabal on topic Non-circular boring. (Linuxcnc fun)
Hi
This is a dream lool fantastic result this is awesome.
Did you plan to share some recent files ?
I thinks this need to be associated with something like the Lathemacro.
Br
30 Apr 2020 14:55 #166223 by skunkworks
I forgot to get the hal file from the shop... I will soon.
Hi
Br
30 Apr 2020 15:02 #166224 by MovT
Replied by MovT on topic Non-circular boring. (Linuxcnc fun)
Awsome work indeed. Can you also describe how i can get this work for ppl with not much experience in LinuxCNC? :)
A little How-To would be perfect.
Thanks.
Best,
Udo
30 Apr 2020 15:09 #166225 by skunkworks
On the to-do list is to make a sample config... (this is pretty clunky currently)
Thanks.
Best,
Udo
30 Apr 2020 15:10 #166226 by skunkworks
Cutter relief is important... The one on the right was cutting higher up on the tool at the corners.. (causing the artifacts)
The slight line going down the 'flat' is backlash comp..
The following user(s) said Thank You: joekline9
30 Apr 2020 15:11 #166227 by MovT
That would be awsome! I cant await it.
Thanks!!!
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
01 May 2020 13:44 #166314 by Todd Zuercher
Replied by Todd Zuercher on topic Non-circular boring. (Linuxcnc fun)
Cool, but I have to ask. What the heck would you use those twisted hex pockets for anyway?
01 May 2020 14:02 - 01 May 2020 14:03 #166320 by skunkworks
Umm.. We don't ask those sorts of questions around here... ;)
Last edit: 01 May 2020 14:03 by skunkworks.
Time to create page: 0.408 seconds
