How to calculate max velocity Mesa card can handle
- Thank you received: 5337
15 Sep 2021 13:59 #220732
Replied by PCW on topic How to calculate max velocity Mesa card can handle
That looks correct but that is the velocity bound of the stepgen.
The actual maximum joint velocity should only be about 75% to 90%
of this value so there is some headroom.
- Clive S
- Thank you received: 486
15 Sep 2021 14:26 #220735
by Clive S
Just for clarification is the steps_per_turn the screw or the motor shaft?
Replied by Clive S on topic How to calculate max velocity Mesa card can handle
Thanks for confirming Peter.That looks correct but that is the velocity bound of the stepgen.
15 Sep 2021 16:07 #220738
The screw, though you could add a motor/screw ratio for belt driven
ballscrews
ballscrews
- Clive S
15 Sep 2021 16:39 #220741
by Clive S
I must be missing something. Motor screw ratio !!
re: 1E9*Lead_Screw_pitch / (reduction*steps_per_turn*(StepLen+Stepspace))
I thought that the reduction from the motor to the screw controlled that in my case.
1.8 reduction from the motor_belt_screw.
ballscrews
Time to create page: 1.079 seconds
