new hal modul
17 Dec 2020 07:31 #192231 by Grotius
Replied by Grotius on topic new hal modul
@ Rod,
Its good to see grotius helping. I helped him a lot when he was learning C so now he's paying it forward!
Thanks for helping me in the past Rod !
How is life in Australia at the moment?
17 Dec 2020 07:43 #192233 by rodw
Replied by rodw on topic new hal modul
@ Rod,
Pretty busy actually. Not enough time to play with plasma cutters!
17 Dec 2020 15:57 - 17 Dec 2020 16:00 #192254 by chris@cnc
Replied by chris@cnc on topic new hal modul
Its working now. And Rod you are right Syntax
timer += fperiod;
is cleaner. Is only one variable necessary and in halshow is timer now only 0.3 digit variable.
For everyone how need one timer output control. May its also useful for flashing signal light.
Warning: Spoiler!
Last edit: 17 Dec 2020 16:00 by chris@cnc.
17 Dec 2020 22:10 #192274 by Himarc3D
Replied by Himarc3D on topic new hal modul
Linuxcnc have classic ladder and its powerful.
For one timer control 3 rungs you can get it, C/C++ is best for complex task like motion control.
The classic ladder editor you can see the the status of variable, status of logic result.
Here at forum root boy and big john have nice examples to setup it. I bet if you try the same using ladder in 2 days you get it
  • The Feral Engineer
  • The Feral Engineer's Avatar
  • Senior Member
  • Senior Member
23 Dec 2020 18:52 - 23 Dec 2020 18:53 #193002 by The Feral Engineer
Replied by The Feral Engineer on topic new hal modul
If you'd like some help putting this together in classicladder, I'd be willing to give it a go :cheer:
Last edit: 23 Dec 2020 18:53 by The Feral Engineer.
23 Dec 2020 20:49 #193019 by chris@cnc
Thanks for the offer but the module works great and the code in the Hal is very short. So far all of my options have been very simple and I didn't really need the ladder. And this was one of the last ones and I didn't want to start with it. Maybe with the next machine. My last option is to be a 4th axis. It should be switchable from velocity to position control. I would like to be able to program speed or angle one day. And that's more difficult than expected. If you have an idea that would be great. The problem is to configure a second spindle that can also be a c-axis.
Time to create page: 3.637 seconds
