Step/Dir servos + Encoders = follow errors... and so much pain.....
01 Feb 2021 22:39 #197341 by jhandel
Is there any Firmware changes I need to make to my Mesa card for this (do I need to recompile my HAL files and flash for instance?
If not, I'll pull down and build master this weekend and give it a test and let you know if I run into any bugs..
and thanks!
01 Feb 2021 22:45 #197343 by PCW
Yes, it needs new firmware for a couple of reasons:
1. The stepgen firmware needed some bug fixes and also you need
a pinout that brings out the stepgen index signal.
2. The firmware has a different stepgen revision to tell the driver
that it has the index (and probe) capability
01 Feb 2021 23:07 #197346 by jhandel
Ok, So I will need to recompile my Bit file and re-flash the card.. No problem....
Are the updated source vhd files and such all published out to mesanet.com or should I be looking elseware for those? (being a noob my bit file was built off of customizations to the hostmot2 source found in that zip.. )
I don't see them in your merge to master, so I am not sure where to download those updates for the new bit file..
01 Feb 2021 23:42 #197350 by PCW
I will update the card zip files later today
01 Feb 2021 23:43 #197351 by jhandel
02 Feb 2021 01:34 #197368 by PCW
OK the firmware source has been updated,
This pinout file has an example of a stepgen index pin and
the stepgen version needed for the firmware to activate the
index (and probe) features
PIN_7I96_StepIDXD_51.vhd
02 Feb 2021 02:02 #197369 by jhandel
Thanks,
I'll copy from there and re-apply my changes and build a new bit file..
Thanks!
02 Feb 2021 02:42 #197370 by jhandel
To confirm (while I am comparing what actually changed in PIN_7i96_StepIDXD_51.vhd is StepGenTag, x"C2" on line 77 (instead of StepGenTag, x"02" found on line 77 in PIN_7i96D_51.vhd)
Along with updated (which is the important part)
hostmot2sp6.vhd
IDROMConst.vhd
hostmot2.vhd
files in the root.
Just wanted to confirm those details as I work on porting my custom vhd and when I looked at your referenced file I didn't see anything different than that compared to PIN_7i96D_51.vhd
04 Feb 2021 00:43 - 04 Feb 2021 00:43 #197608 by PCW
The stepgen version changed (0xC2 means supports index and probe and step/dir swap)
Also you must of course have a pin for the stepgen index in the pin section
Also please refetch the firmware source, I missed one change in the index
capable stepgen firmware when DPLL is present that ended up disabling
the DPLL feature of the stepgen.
(I only noticed this because I plotted the following error)
Last edit: 04 Feb 2021 00:43 by PCW.
04 Feb 2021 01:25 #197612 by jhandel
Is the new StepGen Index Pin a HAL pin I need to worry about? When I look at PIN_7I96_StepIDXD_51 I don't see any thing that jumps out as a StepGen Index Pin.
As I understand the process its:
1) Update my StepGenTag on my 7i76's custom vhd to C2
2) Build using the new source files
- Specifically the following vhd's: kubstepgenzid, hostmot2sp6, IDROMConst, hostmot2, kubstepgenzi, kubstepgenz, kubstepgenzd
- but really just make sure I am using the new source hostmot2 folder and I'll catch those by default
3) Pull master from Mesaflash, build and flash my 7i76 with the new bit file
4) Pull master for Linuxcnc, build and install
After that its Hal update time. First to go from 2.8 to 2.9, then to incorporate these changes...
Oh and testing, lots of testing :)
Does that sound about right?
Time to create page: 0.464 seconds
