CNC Y-axis error
5 years 9 months ago #195070 by hadcom
CNC Y-axis error was created by hadcom
Hello guys,
i am exceptionaly asking for help, i have a little issue with my CNC, i am using a 7i76e Mesa running 3 axis, i experience a dimensional error in my Y-axis. I have 3 linear scales, the Y-axis has a linear of 5um resolution and a closed loop stepper motor attached to a 1605 ballscrew (16mm width, 5mm pitch), so my problem is that i have an "accurate" innacuracy that means my axis undershoot exactly 0,1mm in other words it mills 19,9mm instead of 20mm or 299,9mm instead of 300mm and so on... i dont know how to fix it without using Backlash = 0,1 because my ballscew has no backlash on the dial gauge. Does anyone has a simple solution on how to add 0,1mm to the .HAL file?
Thank you very much guys !
5 years 9 months ago #195073 by andypugh
Replied by andypugh on topic CNC Y-axis error
Is it -0.01 on internal shapes and +0.01 on external? Or the other way round? Or neither?
5 years 9 months ago #195077 by hadcom
Replied by hadcom on topic CNC Y-axis error
Thank you for your response Andypugh!
Saying that the target is a D10mm boring, it becomes D9.90 mm, if it is D10mm outer round shape it becomes D9.90mm (only in Y) X Axis is in both shapes D10mm
5 years 9 months ago #195079 by andypugh
Do the glass scales say that the axis is in the right place?
This is very hard to explain.
5 years 9 months ago #195082 by hadcom
Yes they do say that they are in the right place
5 years 9 months ago #195083 by hadcom
If i just could say to the machine net y-pos-cmd => pid.y.command + 0.1 it would be perfect but unfortunaly it's not that easy to add 0.1mm :(
Time to create page: 0.144 seconds
