SSI ABS Encoder
5 years 5 months ago #208105 by nhanpham
Replied by nhanpham on topic SSI ABS Encoder
andypugh wrote: counts-per-rev should probably be 4096. But that isn't the problem.
Setting it to a much larger number might be an interesting experiment, though.
Is there any way to see the raw data from the encoder? if no-wrap is active then the driver doesn't do very much with the data that comes back. Is it possible that what you see is the actual numbers from the encoder?
I think you can use "enable_raw" in the loadrt hostmot2 line of the hal and peek at the actual register values on the FPGA.
linuxcnc.org/docs/2.8/html/man/man9/hostmot2.9.html#Raw%20Mode
I have attached the hostmot2 register map so that you know where to look.
i have used an oscilloscope to see data. it returns a correct value from 0->4095
5 years 5 months ago - 5 years 5 months ago #208106 by PCW
Replied by PCW on topic SSI ABS Encoder
Sounds like the data is corrupted/shifted
inverted clock maybe?
Andys raw read suggestion is good
For debugging, its important to see what the FPGA reads
Last edit: 5 years 5 months ago by PCW.
5 years 5 months ago #208112 by nhanpham
andypugh wrote: Specifically this bit..
SSI Data Register0, right justifed. Writes to this location will start a read cycle for the specific SSI interface addressed 0x6900 SSI data register0 channel 0 0x6904 SSI data register0 channel 1 0x6908 SSI data register0 channel 2 0x690C SSI data register0 channel 3 ... 0x6A00 SSI data register1 channel 0 0x6A04 SSI data register1 channel 1 0x6A08 SSI data register1 channel 2 0x6A0C SSI data register1 channel 3
Is it correct?
setp hm2_7i80.0.raw.read_address 0x6900 show pin hm2_7i80.0.read_data
The values return from 0x0000000->0x0000ffff for 0->4096
thank you for your helping
5 years 5 months ago #208116 by PCW
What does hm2_7i80.0.ssi.00.zencoder.rawcounts
show?
5 years 5 months ago - 3 years 11 months ago #208118 by nhanpham
PCW wrote: What does hm2_7i80.0.ssi.00.zencoder.rawcounts
show?
it shows from 0-4096
But when I restart linux cnc, the values (3072 to 4096 ) is negative numbers from -1024 ->-1
Last edit: 3 years 11 months ago by nhanpham.
5 years 5 months ago #208121 by andypugh
Replied by andypugh on topic SSI ABS Encoder
annhandt09 wrote: The values return from 0x0000000->0x0000ffff for 0->4096
This is starting to look like it's my fault, then.
However I am fairly sure that the encoder wrapping logic works properly, as it is used extensively by things like the smart-serial MPG counters.
Is the returned position continuous at least? If it is then the conventional axis home offsets will mask the issue.
