VFD is what I meant.
I guess the best would be to have some kind of gear (low for c-axis and high for lathe work) with some way to electrically switch from one to the other.
My commercial lathe has a big gear on the spindle, and a servo with a pinion. Servo is mounted on a swinging bracket connected to an air cylinder.
Engage the C-axis and the main spindle motor is deactivated and the air cylinder shoves the servo (actually a 5-phase closed-loop stepper) against the spindle gear. Once they're engaged the C-axis immediately homes before anything else happens. Looking at the gears, I think it's about 40:1 reduction.
Main spindle motor is a 5kw, 7k rpm 3-phase induction motor with a Lenze VFD, driven via a 1:1 10-rib micro-V belt. The main motor and the stepper both have encoders, but there's also a separate shaft encoder with a 1:1 timing belt connected to the spindle.
The two motor encoders are fed in to the respective drives, but my guess is that the spindle encoder is what the control uses for velocity and positioning control.
As an alternative configuration, there's a guy on YT who's been doing some interesting stuff with his lathe and a Centroid Acorn. Specifically, he's got a standard VFD/induction motor, and separate servo connected via a timing belt. The servo has an electric clutch to engage/disengage when the C-axis is active.
I considered going that route, but toothed electric clutches are
very not-cheap new. And I don't want to depend on an ebay score only to have a scorchingly expensive replacement bill if it dies int he future.
@NoJo -
Thank you very much for the updates and files. This will go a long way towards a number of us making progress.
-Ralph
