- Thank you received: 62
Carousel does not require that, but it can do that.WRT the ATC - If I recall, the basic carousel comp requires the ATC hardware to be able to rotate the carousel, past the tool locate point, a pawn then engages and the carousel is then rotated backwards to lock against the pawl ( EMCO style..)
That was me. I paid for a F360 PP for use with Emco's WinPC version of Fanuc 21TB. It includes a bar-puller macro, as well as radial/axial live tool functions. Milling/drilling is output using XZC moves and does not require G12.1 polar interpolation in the controller, although the Emco does, in fact, have G12.1 available.Your contributions to this thread are very interesting. You say you have paid for the design of a postprocessor for F360 to manage the C axis and you make it available to anyone who may be interested in using it, which seems very commendable to me. Could you then share it with me? Even if you had to contribute some money to obtain it
