- Configuring LinuxCNC
- Advanced Configuration
- Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
- spumco
- Thank you received: 905
22 May 2025 16:46 #328945
by spumco
Replied by spumco on topic Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
That sounds interesting. How are you planning to couple the secondary motor to the spindle?At a later stage, I plan to add an additional 1kW servo motor, which will operate in torque mode to act as a dynamic load on the main 7kW motor. This will increase the system's rigidity. Currently, I'm using the encoder from the main motor
- besriworld
- Thank you received: 92
23 May 2025 01:05 #328961
by besriworld
Replied by besriworld on topic Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
I’ve bought a hydraulic chuck closer for the lathe chuck, but in order to mount it onto the spindle shaft, I need to cut a thread on the spindle. After that, I’ll add an additional gear on the spindle, which will be connected by a belt to a second servo motor with a 1:2 gear ratio. The motor will be mounted on top of the spindle housing
23 May 2025 14:38 #329005
Replied by andypugh on topic Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
Yes, it's probably best to turn off CSS when threading.
There is still an issue with threading in LCNC - thread start point varies with RPM - but that's not related to caxis.comp.
- spumco
23 May 2025 15:13 #329009
by spumco
Andy,
I wasn't using CSS when threading. Multiple attempts at tapping the same thread at different speeds resulted in different start points.
What I discovered (through @Aciera's help) was that caxis.comp interfered with threading/tapping, and that LCNC has a bug in G33.1 and G76.
forum.linuxcnc.org/38-general-linuxcnc-q...peed?start=30#317931
Andy,
- Thank you received: 5336
23 May 2025 19:51 - 23 May 2025 19:51 #329025
Replied by PCW on topic Developments on my Home built 5C CNC Lathe - Polar interp. and Live tooling
Yes, this definitely seems like a bug.
I can see the cut starting at a different place at different spindle
speeds due to the time needed to get synched to the spindle
varying at different spindle speeds, _but_ once synced and cutting,
the threads should be identical regardless of spindle speed...
(as they are in a normal manual lathe than maintains strict gearing
between the spindle angular position and Z offset)
Last edit: 23 May 2025 19:51 by PCW.
