- Thank you received: 2181
Probe screen v2 - malfunction?
4 years 10 months ago - 4 years 10 months ago #229690
Replied by cmorley on topic Probe screen v2 - malfunction?
There are specific times the a probe trip will and won't cause an error if tripped, unfortunately I forget the cafeteria.
It may be when feeding it will , when rapid-ing it won't
But your problem sounds related to the gladevcp panel rather then the probe.
Keystroke forwarding (from gladevcp to AXIS) has been a problem in the past.
Last edit: 4 years 10 months ago by cmorley.
- hIGGI
- Thank you received: 3
4 years 8 months ago #233734
by hIGGI
Replied by hIGGI on topic Probe screen v2 - malfunction?
Looks like i have same issue with crashing probe (and xhc pendant), maybe is it relevant (config for pendant interfering with config for probe)?
- CBollweg
- Visitor
4 years 8 months ago #234570
by CBollweg
Replied by CBollweg on topic Probe screen v2 - malfunction?
Hello, I have the same problem. When I move the handwheel and the probe trips, the mascine doesn't stop. I found a solution with MUX2 in an old wiki and am trying to find a solution with the motion.motion-type. Maybe someone has already done this?
Would be grateful for any help to avoid expensive mistakes in the future. Thanks in advance
Christian
Christian
- chrischan
1 year 4 weeks ago #335827
by chrischan
Replied by chrischan on topic Probe screen v2 - malfunction?
Hey guys
I have similar problem.
When hitting page up or page down button, the z axis starts moving until the end stops. And only stops moving if probe sensor is touched or esc button.
Why does the probe screen behaves that way?
is it possible to remove this function?
I started to read the different py files, but didn't find a clue to this problem.
1 year 3 weeks ago #336001
Replied by andypugh on topic Probe screen v2 - malfunction?
Just to clarify, when you say "Probe screen v2" what are you referring to?
Is this: github.com/LinuxCNC/linuxcnc/tree/master...n-panels/versa-probe
Or some other probe screen?
- chrischan
1 year 3 weeks ago - 1 year 3 weeks ago #336003
by chrischan
Sorry, my mistake. It is probe screen 2.9 from verser-git.
But I have similar problem like Marcodi:
Same happens with my machine. And also when using page up and down with the z axis.So whenever you are inside of the probe screen and you use the keyboard numbers 2-8 4-6 and 3-9. The machine starts moving in the appropriate direction without stopping until it hits a limit switch
Last edit: 1 year 3 weeks ago by chrischan.
Time to create page: 1.021 seconds
