- Thank you received: 75
Yes, that’s correct, the servos are controlled with 7i77 through +-10V. When the 10V output and the encoder input of X are disconnected, it slowly drifts. Only visible with dial indicator. Or if I wait some time then its visible by eye.As for interface - you control your servos with analog voltage reference as I understood.
P of X is 2, but with P=1 i get the same results. Should I decrease it even more?I think you have big values of "P" parameters in ini file, try do decreese them.
