Switch relay in a defined x position
4 years 9 months ago #232171 by rodw
That does not really answer the question. I'm sure Andy does not use MX Linux and neither do I.
Do those instructions require you to use make or did you use synaptic or apt?
Also errors should have a line number reported. check which line it fails on and what is on that line.
4 years 9 months ago #232174 by mgm
I installed it with synaptic.
The error message is in the line:
Addf downdraft servo thread
4 years 9 months ago #232175 by rodw
Did you use sudo when you used halcompile. you need root access to write to the folder.
4 years 9 months ago #232176 by mgm
Yes I have used Sudo
4 years 9 months ago #232177 by mgm
This is the result of halcompile:
compiling realtime downdraft.c
Linking downdraft.so
cp downdraft.so /usr/lib/linuxcnc/modules/
Is this the right place to put the file?
4 years 9 months ago #232179 by rodw
sudo halcompile --install
allways works for me.
Perhaps try the comp and wcomp components Andy linked to as they are part of the core.
Time to create page: 0.471 seconds
