Switch relay in a defined x position
18 Jan 2022 18:40 #232311 by mgm
Replied by mgm on topic Switch relay in a defined x position
Success message it works great
You are the greatest guys thank you!
There was still some grumbling in one place but that could be fixed quickly.
Here again for the sake of completeness.
The following must be entered in the hal:
loadrt downdraft name=ddraft
addf ddraft servo-thread
net position axis.x.pos-cmd. => ddraft.position
net ddraft-trigger ddraft.trigger
setp ddraft cutover 800
setp ddraft cutoff 1200
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
18 Jan 2022 19:40 #232320 by rodw
Replied by rodw on topic Switch relay in a defined x position
great work, glad it works for you.
Custom components are so simple yet so few know they can be written
12 Jul 2022 13:43 #247139 by caretech
Replied by caretech on topic Switch relay in a defined x position
Isn't this something that the built-on "comp" or "wcomp" components can do?
linuxcnc.org/docs/2.8/html/man/man9/comp.9.html
linuxcnc.org/docs/2.8/html/man/man9/wcomp.9.html
Do you know of a code snippet anywhere as an example of how we might use comp or wcomp to trigger pins based on X axis position? I have built a 5 x 10 table and am building a zoned downdraft system for it with five zones. I want one zone open at a time based on position of the X axis; and a time delay so that open zones do not close for a few seconds after X has moved out of  a zone. I am not concerned with the position of Y.
12 Jul 2022 13:55 - 12 Jul 2022 14:07 #247143 by tommylight
Replied by tommylight on topic Switch relay in a defined x position
RodW and another member have such a system in use, so it can be done.
How, i'll leave that to them to explain.
Found one of the topics:
forum.linuxcnc.org/plasma-laser/40517-do...gn-questions?start=0
Last edit: 12 Jul 2022 14:07 by tommylight. Reason: added link
The following user(s) said Thank You: caretech
12 Jul 2022 14:07 #247145 by caretech
I figured I'd probably take the component Rodw provided in this thread and modify it as needed for my table, but was wondering if there would be reasons why using built-in components would be better. For instance will the "halcompile" step be needed again after upgrading LinuxCNC? I built on MX Linux 21.
Then again, now it just occurred to me that as far as custom components go I'm using Rod's ohmic3.comp for ohmic probing with a THCAD-5. So... if custom components need to be reinstalled after upgrading I am not clear of that anyhow. I'll go study the downdraft component provided in the other thread some more.
12 Jul 2022 14:12 - 12 Jul 2022 14:12 #247147 by mgm
I have a spindle support which is retracted and extended with a pneumatic cylinder. The cylinder is controlled via a relay which is controlled with a digital output of the Mesacard.
Attached is the comp file.
This is the hal entry
# --- Spindle support---
net position axis.x.pos-cmd => spport.position
net spport-trigger spport.trigger => hm2_7i76e.0.7i76.0.0.output-05
setp spport.on 700
setp spport.off 1900
Last edit: 12 Jul 2022 14:12 by mgm.
12 Jul 2022 15:13 - 12 Jul 2022 15:18 #247154 by itsme
Replied by itsme on topic Switch relay in a defined x position
loadrt wcomp names=wcomp_segment0,wcomp_segment1,wcomp_segment2,wcomp_segment3,wcomp_segment4,wcomp_segment5
loadrt not names=not_segment0,not_segment1,not_segment2,not_segment3,not_segment4,not_segment5
addf wcomp_segment0    servo-thread
addf wcomp_segment1    servo-thread
addf wcomp_segment2    servo-thread
addf wcomp_segment3    servo-thread
addf wcomp_segment4    servo-thread
addf wcomp_segment5    servo-thread
setp wcomp_segment0.min    -456
setp wcomp_segment0.max    -44
setp wcomp_segment1.min    -144
setp wcomp_segment1.max    268
setp wcomp_segment2.min    168
setp wcomp_segment2.max    580
setp wcomp_segment3.min    480
setp wcomp_segment3.max    892
setp wcomp_segment4.min    792
setp wcomp_segment4.max    1204
setp wcomp_segment5.min    1104
setp wcomp_segment5.max    1516
#SEGMENTS switching
net y_curr_pos axis.y.pos-cmd wcomp_segment0.in wcomp_segment1.in wcomp_segment2.in wcomp_segment3.in wcomp_segment4.in wcomp_segment5.in
net within_segment0 wcomp_segment0.out => not_segment0.in
net within_segment1 wcomp_segment1.out => not_segment1.in
net within_segment2 wcomp_segment2.out => not_segment2.in
net within_segment3 wcomp_segment3.out => not_segment3.in
net within_segment4 wcomp_segment4.out => not_segment4.in
net within_segment5 wcomp_segment5.out => not_segment5.in
# i use GPIO 11, 09, 10, 25, 08, 07 segment0-5, thats rpin 23, 21, 19, 22, 24, 26
net not_within_segment0 not_segment0.out => hal_pi_gpio.pin-23-out
net not_within_segment1 not_segment1.out => hal_pi_gpio.pin-21-out
net not_within_segment2 not_segment2.out => hal_pi_gpio.pin-19-out
net not_within_segment3 not_segment3.out => hal_pi_gpio.pin-22-out
net not_within_segment4 not_segment4.out => hal_pi_gpio.pin-24-out
net not_within_segment5 not_segment5.out => hal_pi_gpio.pin-26-out
I use a RPI4 and have to use inverted outputs, thus the not usage...
There are 6 (overlapping) segments configured on y axis.
Last edit: 12 Jul 2022 15:18 by itsme.
03 Aug 2025 19:34 #332752 by mgm
Hello everyone,
I would like to revisit this topic.
The component has been working very well and reliably for three years now.
Unfortunately, I have already broken the spindle support twice, but this was not due to the component itself, but rather to the compressed air in our workshop.
I would therefore like to install a position switch to check the position of the cylinder and ensure that it is actually retracted.
To do this, the component would need to be expanded with an additional pin and a query.
Now my question to you, or rather to Rod, is whether you could help me with this again?
This is the current Comp file:
component spinport "LinuxCNC HAL component that switches the spindle support";
description
Component to trigger the spindle support
\\fBEXAMPLE:\\fR
.br
.br
loadrt spinport names=spport
.br
addf spport servo-thread
.br
net position axis.y.pos-cmd    => spport.position
.br
setp spport.on 900
.br
setp spport.off 1600
.br
author "Rod Webster";
pin   in  float position    "Motion signal for Axis position";
pin   out bit trigger       "True if spinport segment should be triggered";
param rw  float on     "Absolute axis coordinate from which the support is retracted";
param rw  float off      "Absolute axis coordinate from which the support is extended";
function _;
license "GPL";
#include <rtapi_math.h>
FUNCTION(_) {
  if((position > on)&&(position < off))
    trigger = 0;
  else
    trigger = 1;
03 Aug 2025 21:33 #332763 by Benb
Replied by Benb on topic Switch relay in a defined x position
The following hal file is based on linuxcnc wcomp component.
The file was automatically generated by the eagle2hal script.
# Load realtime Components and their counts
loadrt not          count= 1
loadrt or2          count= 1
loadrt wcomp    count= 1
# Add functions to threads
addf wcomp.0              servo-thread
addf not.0                    servo-thread
addf or2.0                    servo-thread
# Set parameters
setp wcomp.0.max  1600.0
setp wcomp.0.min  900.0
# Connect Pins using signals/wires
net axis.x.pos-cmd wcomp.0.in
net cyln.pos<max&&>min wcomp.0.out  not.0.in
net cyln.pos>max&&<min not.0.out  or2.0.in0
net cyln.extended or2.0.in1  wcomp.0.under
net trigger or2.0.out  hm2_7i76e.0.7i76.0.0.output-05
04 Aug 2025 09:34 #332804 by mgm
Hi Benny,
Thanks for your message!
If I understand correctly, the HAL lines are the implementation of my current comp file, right?
I would now have to add the position switch and the query for the switch position and then connect it to the emergency stop if the position is incorrect.
Do I add the HAL lines to my existing HAL?
