Another servo tuning
4 years 6 months ago #239556 by myval
Replied by myval on topic Another servo tuning
Right with the deriv connected I get the attached curve.
will play with maxaccel in a minute
4 years 6 months ago #239557 by myval
Stepgen maxaccel at 0
4 years 6 months ago #239558 by andypugh
Replied by andypugh on topic Another servo tuning
Does changing the FF1 value affect the initial deviation when movement starts?
I would concentrate on just that for the moment, try increasing and decreasing FF1 and FF2 (one at a time) and also try changing D (try 0.0001, 0.001, 0.01) and try to get a feel for what changes.
4 years 6 months ago #239559 by myval
an if I drop the axis accel to 100 I have been machining with this setting and the results were seriously good.
but I would like to bump up the max speed and acceleration a bit if we could figure out what is going on.
thanks
4 years 6 months ago - 4 years 6 months ago #239746 by myval
Just to make life easier we had massive storm and power outage. It never ends.
I have tried increasing decreasing FF1 and FF2 and 1 and 0 is about as good as it gets with changing D I can only make it worse.
I am wondering if it is not some kind of system noise because it is very squigly while it is on in steady motion. Could there be a problem with the motor driver? I am feeding it step dir instead the usual +-10v
This is just a thought I am guessing that Peter could shine some light on this.
Would it be better if I reconfigure drives for lets say PWM dir?
I could not use the original Bosch servo drives and the first try was with small cheap drivers which ony had Step Dir but the new once I have can be set into different types of inputs.
I have drives set in position control too.
Could any of these cause these issues?
correction: can only set it to PWM 50% zero set point not PWM dir
Last edit: 4 years 6 months ago by myval.
4 years 6 months ago #239758 by PCW
Replied by PCW on topic Another servo tuning
I would try open loop step/dir first to eliminate possible mechanical
or encoder issues (take feedback from stepgen position rather than
encoder position)
Time to create page: 0.387 seconds
