Running 2 gcode at same time
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
12 Apr 2022 19:22 #240101 by andypugh
Replied by andypugh on topic Running 2 gcode at same time
and on ini file extra_joints can be declared as normal joint?
Yes, in that they can be part of the homing scheme. I am not sure if joint limits are checked.
They do not get allocated to G-code axis letters.
The following user(s) said Thank You: bkt
  • bkt
  • bkt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 Apr 2022 23:57 - 13 Apr 2022 00:01 #240108 by bkt
Replied by bkt on topic Running 2 gcode at same time
And in your opinion can test with axis gui these: jog/send command with simple_tp to extrajoint.1 and run an MDI with axis.x/joint.0 at same time.
Or in axis gui is not permittet, as with normal joint?
Plus extrajoint have pin for jogging (because not see on manual html)? or only can send value of new position with simple_tp?
bkt
Last edit: 13 Apr 2022 00:01 by bkt.
Time to create page: 0.081 seconds
