Align portal milling cutter
- mgm
- Thank you received: 13
23 Apr 2022 03:09 #240974
by mgm
Align portal milling cutter was created by mgm
I have seen a long time ago on a website a way to align y axis to x axis. Unfortunately the website has been closed!
What I mean is:
If y moves 100 mm x should be automatically corrected by 0.1mm!
Can someone help me there?
What I mean is:
23 Apr 2022 03:32 #240976
Replied by andypugh on topic Align portal milling cutter
"millkins" does this, but might need changes to work properly with a dual-motor axis if you have one.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...omponents#Kinematics
linuxcnc.org/docs/stable/html/motion/kinematics.html
- mgm
24 Apr 2022 10:36 #241074
by mgm
Replied by mgm on topic Align portal milling cutter
Yes I have 2 motors on the Y axis.
I have now experimented in a sim today, but unfortunately without success. I keep getting an error message that the limit is exceeded! I suppose that is but on the joint assignment!
Then I tried in the millkins to add a second y axis, but honestly I have no idea what I'm doing .....
Is there anyone who has the millkins with two y motors running?
25 Apr 2022 05:09 #241183
The sims have simulated limit switches and do tend to get a bit tangled up sometimes. (Hmm, we should probably try to fix that)
Are you using auto-squaring (ie, there are two home switches for Y and negative homing sequence numbers in the INI?)
- Thank you received: 4154
25 Apr 2022 05:57 #241190
Replied by rodw on topic Align portal milling cutter
I seem to remember writing a custom component to do this for another member in a few lines of code. Its here on the forum somewhereI have seen a long time ago on a website a way to align y axis to x axis. Unfortunately the website has been closed!
What I mean is:
25 Apr 2022 08:01 - 25 Apr 2022 08:01 #241203
Here is a version of millkins for an XYZY configuration (XYZY is hard-coded in)
sudo halcompile --install skewkins.c
Should install it. If you don't see a "cp ... skewkins...." towards the end of the output then it hasn't worked. In that case paste the output here.
Last edit: 25 Apr 2022 08:01 by andypugh.
- mgm
25 Apr 2022 13:19 #241231
by mgm
Hello Andy
Thanks for the info ...
I already have 2 limit switches on y and also the negative homesequence.
My partal is made of MULTIPLEX and has a length of 3000mm.
Unfortunately, the table with the side guides is 1mm wider at the back than at the front and so I have quite exaggerated a "V".
I have now so mediated that I have on both sides now at 1000 mm in y 3/10.
The machine is used to make furniture.
Thanks for adjusting the millkins.
I will try it out ......
27 Apr 2022 18:23 #241413
And?
- mgm
28 Apr 2022 06:28 #241457
by mgm
sorry that I have not yet answered but in the workshop is currently stress announced!
But I have just tried it.
skewkins has compiled
But if I now change the entries in the hall I get an error:
28 Apr 2022 07:01 #241462
Ah, interesting....
This is related to the addition of switchable kinematics to LinuxCNC master.
Add
to the .c file just above the "EXPORT_FUNCTION" lines
Add
KINS_NOT_SWITCHABLEto the .c file just above the "EXPORT_FUNCTION" lines
Time to create page: 1.164 seconds
