Lathe with FRONT & BACK tool posts?
16 Jun 2022 05:09 #245250 by robertspark
Lathe with FRONT & BACK tool posts? was created by robertspark
I'm sure that there is probably an easy answer to this, but, how would one deal with a Lathe that has 2x quick change toolposts, one as a front and the other as a a rear toolpost?
{The GUI is Gmoccapy if it makes a difference}
I know about the ini file setting
[DISPLAY] BACK_TOOL_LATHE = 1
Just wondering how to practically deal with this.
I know I've seen a parting tool on the rear toolpost sometimes, but it seems that this lathe has 2x 4 position quick change toolposts.... one front and one rear mounted.
Anyone come across this before or got a solution?
Thanks in advance.
Rob
17 Jun 2022 15:34 #245349 by spumco
Replied by spumco on topic Lathe with FRONT & BACK tool posts?
Robert - been lurking as this interests me as well.  I don't have any personal experience (my lathe isn't LCNC), but I did find a couple threads addressing the issue.
Remap G68/G69
forum.linuxcnc.org/26-turning/24729-gang...ools?start=40#193678
This looked useful
forum.linuxcnc.org/38-general-linuxcnc-q...help?start=10#215160
Just thought of something... Pathpilot has both a turret and gang tools.  Poking around in PP or asking questions from the PP folks may be instructive how Tormach handles the tool display.
17 Jun 2022 15:40 #245351 by robertspark
Replied by robertspark on topic Lathe with FRONT & BACK tool posts?
thanks v much, i'll take a look (its not my setup, but i could see I could be asked to help someone out
17 Jun 2022 16:37 #245353 by cmorley
Replied by cmorley on topic Lathe with FRONT & BACK tool posts?
You can mirror the X axis to use the back tool more easily.
Its a bit hacky as you must partially define a fake Y axis in the INI so that the g10 l2 rotate command will work. then you rotate the X axis 180 degrees
The following user(s) said Thank You: robertspark, spumco
Time to create page: 0.157 seconds
