Okuma lathe retrofit servo help
17 Jul 2021 18:15 #215160 by Henk
Replied by Henk on topic Okuma lathe retrofit servo help
Hi. We operate a lathe with two turrets similar to your setup. Basically, we use the rear turret with negative x values. The tool orientation is still as per the manual. G2,G3,G41/42 is opposite to the normal setup on the positive side of the center line.
Alternatively, you can issue a G10L2P1R180 before using the rear tool. This works as well. I've tested this, but not used it much.
There is also a cam postprocessor for fusion 360 that allows use of the back tool successfully.
17 Jul 2021 23:51 #215189 by cmorley
Replied by cmorley on topic Okuma lathe retrofit servo help
remapping the g10 command is a nice way to go.
I haven't tested this technique on my lathe but played with a simulator.
It doesn't reverse the spindle but you could probably add that too.
Time to create page: 0.804 seconds
