*SOLVED* Recompiling genhexkins
- cncbasher
- Thank you received: 288
these work and compile fine
against 2.6.0 pre~
place armkins.c and armkins.h in emc-dev2/src/emc/kinematics
and replace your makefile in emc-dev2/src
and then rebuild as normal
dont forget to keep copy of your origionals
- honey
cncbasher wrote:
So I should:find attached your armkins file and my emc makefile
against 2.6.0 pre~
- place armkins.c and armkins.h in emc2-dev/src/emc/kinematics
- place the make file that you have attached me in emc2-dev/src
- and rebuild.
I should rebuild with only "make"? or I should use . ./scripts/emc-environment ?
- cncbasher
and then build , i use a script file for this purpose it's easier than typing it out all the time
iv'e attached it here , you may need to modify to suit your needs
- cncbasher
iv'e attached it here , you may need to modify to suit your needs , it's simple enough
- honey
you should use source ./scripts/emc-environment
How I should use this script? I am not so expert....
- cncbasher
in my case home/david
and my emc dev is placed in home/david/emc2-dev
if you right click on the script file make sure that under the permissions tab that Execute is ticked
then close
clicking on the script file now should give you the option to run
or alternatively just ./build-emc ( period . means execute the program ) from a terminal
- honey
Someone can read my kinematic file armkins.c and give me some advice?
- Thank you received: 4967
module that I have written is not completly correct because when I switch on world mode the coordinates x and z drive crazy...
I might get time later, but I have previously looked at a similar kinematics and found it very helpful to set up a spreadsheet that performs the forwards then reverse calculations on a few positions, to see if the same numbers that went in come out again.
- cncbasher
can you post a video showing the error etc
and what you expect to happen
- honey
You can me explain better what you mean? the values of the links of robot?where are you initializing your default values ?
As soon as I switch on world mode, the values of x and z changing always and never stop. I do nothing, just change mode and I have this strange thing!
