*SOLVED* Recompiling genhexkins
- Thank you received: 4994
I don't really follow the maths, though, as I never did really get the hang of rotation vectors.
Is it possible that something is wrong with the homing part of your kinematics file?
- honey
I had a quick look, but I can't compile your kinematic without armkins.h as you have defined the flags there.
Sorry, you are right. I attach the file here
Yes It is possible. Really I don't understand how the kinematics module (pumakins or others) use the homing part. You can me help with this? What I should do?
Nor do I, but I imagine that the idea is that you home each joint, then when you switch to world-mode it runs the homing subroutine once to get an unambiguous position, then starts running kins normally. So, you might get an f-error if your homing routine gives a different answer to the inverse kins. In your case you might need the homing routine to set the iflags before calling the inverse kins.Yes It is possible. Really I don't understand how the kinematics module (pumakins or others) use the homing part.
- honey
So, what I should do? change something in my kinematics file or change home values in ini file??
I really don't know. I think you need help from someone who understands the kinematics structure. You might get lucky with a query on the mailing lists (possibly the developer list) but you are more likely to get no response.So, what I should do? change something in my kinematics file or change home values in ini file??
It seems to me that this aspect of EMC2 is rather badly documented, and you might have to read the source code to work it all out.
The comments in kinematics.h explain a few things:
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...ematics/kinematics.h
There are also many useful comments in this file
git.linuxcnc.org/gitweb?p=emc2.git;a=blo...emc/motion/control.c
(at the beginning and line 1464 onwards)
As far as I can see kinematicsHome is _never_ called. I am going to check...
I found that I needed to put it in the kinematics directory, and then needed to edit emc2-dev/src/Makefile to duplicate all (9?) lines which mention genhexkins to add a similar line for armkins. That seems to work nicely.
I think you ought to remove the unused variables, or at least comment out those lines.
As I said on the mailing list, you have some sqrt() functions which might not be correct, and also could do with an fabs() in them to make them more robust. Things go badly wrong if the code tries to take a sqrt of a negative number.
- honey
How are you compiling armkins at the moment?
Yes, as cncbasher suggested, I put armkins in emc2-dev/src/emc/kinematics and I have edit the Makefile adding lines similar to the other kinematics module. Then I compiled with
emc2-dev/src
./configure --enable-run-in-place
make
sudo make setuid
You suggest me to add fabs() where there are sqrt()? In this way the code doesn't try to make a sqrt of a negative number?
- findux
How to integrate stepgen module to parallel kinematic hal file for real time step/dir signal generator? Which companent's output use for step/dir signal? when I use vismach as simalator some times I get poor performans. What happens in real-time.
- PKM
- Thank you received: 3
You can find realtime config for hexapod with steppers here parallelrobots.blogspot.com/2012/04/linu...od-machine-tool.htmlHow to integrate stepgen module to parallel kinematic hal file for real time step/dir signal generator? Which companent's output use for step/dir signal? when I use vismach as simalator some times I get poor performans. What happens in real-time.
