Or it might be best to construct a custom HAL component with the following behaviour:
If the machine is turned off the pin takes a settable default state
if the machine is turned on, the pins retain the default state (or take a different default state?)
If the input toggles from low to high and the machine is on - the output goes high
if the input toggles from high to low and the machine is on - the output goes low.
