- Thank you received: 599
Python Interface Feed Hold
- JT
2 years 5 months ago #299646
by JT
Replied by JT on topic Python Interface Feed Hold
Ok in Axis if M53 is active toggling motion.feed-hold works so it makes me wonder if the GUI is doing it.
JT
JT
- Thank you received: 2181
2 years 5 months ago #299662
Replied by cmorley on topic Python Interface Feed Hold
I think python's feed-hold and M53 are the same thing.
it should have been called feed-hold-enable
I the python module it calls the NML message:
EMC_TRAJ_SET_FH_ENABLE
There seems not to be a equivalent to motions feed-hold in python.
probably nml message:
EMC_TRAJ_HALT_TYPE
EMC_TRAJ_HALT_TYPE
2 years 5 months ago #299666
m53 and python's feed_hold just control a switch for the motion.feed-hold HAL pin.
that pin is used in control.c to set the feed scaling to 0.
if ( enables & FH_ENABLED ) {
/* read feed hold HAL pin */
if ( *emcmot_hal_data->feed_hold ) {
scale = 0;
scale = 0;
- JT
2 years 5 months ago - 2 years 5 months ago #299672
by JT
Chris, thanks for clearing that up.
I just did some testing and python feed-hold true, M53 off and motion.feed-hold stops motion.
With python feed-hold false and M53 active motion.feed-hold does not stop motion.
JT
JT
Last edit: 2 years 5 months ago by JT.
2 years 5 months ago #299712
Replied by andypugh on topic Python Interface Feed Hold
If you set it off in Python then on again with G53, does Python still "win"?
- JT
2 years 5 months ago - 2 years 5 months ago #299722
by JT
Issuing a M53 P0 then turning off python feed-hold (which is really feed-hold-enable) then turning on M53 with M53 P1 the python status feed_hold_enabled is true and setting motion.feed-hold on stops motion.
I 'think' I just misunderstood what does what with python set_feed_hold(int) which should be named set_feed_hold_enabled(int).
Turning off M53 then setting python set_feed_hold true it turns on M53 and updates the python mcodes status.
Setting python set_feed_hold False does not update the python mcodes so it 'looks' like M53 is on when it's really off.
In any case the python status feed_hold_enabled always shows the correct status of feed hold enable.
JT
JT
Time to create page: 0.294 seconds
