I get a tracking error. the scale of my encoder is correct on my B axis display
13 Dec 2024 20:05 #316603 by JackRay
Good morning, gentlemen,
I'm coming back to you because even with your advice I can't adjust my encoder. I still have my “joint 3 tracking error” problem. I've made a short video showing how the position of my encoder reacts, as soon as I touch it, I get a tracking error. on the other hand, the scale of my encoder is correct on my B axis display.
My config file are attach .
Could you help me?
Thank you
13 Dec 2024 20:11 #316606 by PCW
Set your following error limits wide (1 inch or 25 mm)
and post a halscope plot of the following error when
you do a motion.
13 Dec 2024 20:34 #316607 by JackRay
my unit is degrees for a rotating axis. I don't know how to use a halscope.
13 Dec 2024 20:42 #316608 by PCW
Tuning/diagnosis will be quite difficult  without using halscope
04 Jan 2025 14:00 #318064 by tommylight
@JackRay,
Did you get this sorted?
06 Apr 2025 08:34 #325806 by JackRay
Hello, please excuse me for the delay in replying but I have been sick.
Yes, I managed to adjust my PID but not exactly, I still have small ocillations at certain positions of my rotating B-axis.
I saw that there is an Autotune. But impossible to find any practical documentation on this program which apparently makes a PID setting automatically???
I'm looking at how to program an Autotune in python. Sending commands and retrieving data, tracking errors is quite simple with "Import Linuxcnc".
the regylge of a PID is very tedious in length. If an automatic program exists, I'm a taker.
If anyone has any information I'm interested.
Thank you
06 Apr 2025 14:34 #325817 by PCW
Unfortunately Autotune programs do no adjust the feedforward or deadzone terms so fairly useless
in real world situations.
I suspect for the best performance of a position control (stepgen or Ethercat or whatever) with an added
linear feedback device, you would need two PID loops, the local high bandwidth position loop plus a lower bandwidth
PID loop using the linear encoder feedback. This could be done in hal with two PID components with their outputs
summed.
08 Apr 2025 18:46 #325950 by JackRay
Yes thank you but then I have no idea how to do it .
Regards
08 Apr 2025 19:04 #325952 by PCW
At the minimum you should:
Expand the ferror limits as explained above.
Learn to use halscope.
It will not really be possible to tune without using halscope
regardless of the hal setup.
12 Apr 2025 19:50 #326191 by JackRay
but I know how to use the halscope. I know how to read the curves, but I don't know which parameter to adjust when, for example, I have oscillations in the error.
Time to create page: 0.186 seconds
