- Thank you received: 2177
Deckel FP4 Gearbox Comp
2 years 3 months ago #304262
Replied by Aciera on topic Deckel FP4 Gearbox Comp
Well I would have said 'FP4_gearbox.comp' but looking at the component itself has me confused as none of the component pins created seem to be used in the actual function:
Warning: Spoiler!
LinuxCNC component for controlling the Deckel FP4 gearbox.
Copymitte (C) 2018 Sergey 'Jin' Bostandzhyan <jin@mediatomb.cc>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
component FP4_gearbox "Component to control the Deckel FP4 gearbox to set the requested speed";
author "Sergey 'Jin' Bostandzhyan midified by Andreas Benz";
license "GPL";
/* to be connected with motion.spindle−speed−out−abs */
pin in float spindle_speed_in_abs = 0 "Desired spindle speed in rotations per minute, always positive regardless of spindle direction.";
/* to be conneced with motion.spindle−speed−in */
pin out float spindle_speed_out = 0 "Actual spindle speed feedback in revolutions per second";
/* gearbox status pins from the MESA 7i96S */
pin in bit vorgelege_vorne "MESA 7i96S INPUT 2: 28X2-11";
pin in bit vorgelege_mitte "MESA 7i96S INPUT 3: 28X2-11";
pin in bit vorgelege_hinten "MESA 7i96S INPUT 4: 28X2-13";
pin in bit block2_vorne "MESA 7i96S INPUT 5: 28X2-15";
pin in bit block2_mitte "MESA 7i96S INPUT 6: 28X2-16";
pin in bit block2_hinten "MESA 7i96S INPUT 7: 28X2-17";
pin in bit block1_vorne "MESA 7i96S INPUT 8: 28X2-19";
pin in bit block1_mitte "MESA 7i96S INPUT 9: 28X2-20";
pin in bit block1_hinten "MESA 7i96S INPUT 10: 28X2-21";
pin in bit spindle_stopped = 0 "MESA 7i84 INPUT 19: TB2-4";
pin out bit stop_spindle = 0 "Start or stop spindle";
pin out bit spindle_at_speed = 0;
/* control pins */
pin out bit motor_lowspeed = 0 "MESA 7i66 OUTPUT ";
pin out bit vorgelege_motor = 0 "MESA 7i66 OUTPUT C3 7i96S.0.7i66.0.0.output-03";
pin out bit block2_motor = 0 "MESA 7i66 OUTPUT C4 7i96S.0.7i66.0.0.output-04";
pin out bit block1_motor = 0 "MESA 7i66 OUTPUT C5 7i96S.0.7i66.0.0.output-05";
pin out bit rueckziehen = 0 "MESA 7i66 OUTPUT C6 7i96S.0.7i66.0.0.output-06";
pin out bit twitch_cw = 0 "MESA 7i66 OUTPUT 6: 28X1-14";
pin out bit twitch_ccw = 0 "MESA 7i66 OUTPUT 7: 28X1-15";
pin out bit estop_out = 0 "This pin will trigger emergency stop in case of an unrecoverably fatal error.";
pin in bit estop_in "This pin notifies us that an emergency stop was triggered outside the component.";
function _;
option singleton yes;
#include <rtapi_math.h>
#include "FP4_common.h"
#include "FP4_util.h"
#include "FP4_gears.h"
static float g_last_spindle_speed = 0;
static tree_node_t *g_tree_rpm = NULL;
static tree_node_t *g_tree_mask = NULL;
static bool g_setup_done = false;
static bool g_last_estop = false;
/* one time setup, called from the main function to initialize whatever we
* need */
FUNCTION(setup)
int i;
/* Initialize state data structures */
gearbox_setup(__comp_inst, period);
twitch_setup(__comp_inst, period);
/* we want to have key:value pairs in the binary search tree, where
* the value represents the index of the key in our gears array. So
* we'll put things together the way we need them for the tree generation
pair_t temp[FP4_NUM_GEARS];
for (i = 0; i < FP4_NUM_GEARS; i++)
temp.key = FP4_gears.key;
temp.value = i;
/* build up binary tree from the gears array to search by rpm, this
* array is already sorted */
g_tree_rpm = tree_from_sorted_array(temp, FP4_NUM_GEARS);
/* build up a key:value list where the bitmask from the m400e_gears
* array is the key and the index of the original position in the
* above array is the value */
temp.key = FP4_gears.value;
temp.value = i;
/* sort the newly created array by key (needed for tree build up) */
sort_array_by_key(temp, FP4_NUM_GEARS);
/* build up binary tree from the gears array to search for bitmask */
g_tree_mask = tree_from_sorted_array(temp, FP4_NUM_GEARS);
g_last_spindle_speed = spindle_speed_in_abs;
g_last_estop = estop_in;
/* When e-stop is triggered from the outside everything is already powered
* off, but we want to make sure that our pins are also inactive should
* the power come back. We don't have to care about timings here, because
* everything is already off at this point. */
FUNCTION(handle_external_e_stop)
rtapi_print_msg(RTAPI_MSG_ERR, "FP4_gearbox: EMERGENCY STOP condition "
"detected!\n");
/* reset state machine avoiding delays */
gearbox_handle_estop(); /* this function also stops/resets twitching */
spindle_at_speed = false;
stop_spindle = true;
/* reset estop_out pin since we could haave been the ones who triggered
* this e-stop */
estop_out = false;
/* main component function */
FUNCTION(_)
if (estop_in)
if (g_last_estop != estop_in)
handle_external_e_stop(__comp_inst, period);
return;
/* perform one time setup */
if (!g_setup_done)
g_setup_done = true;
/* read and update global mask variables for each pin group */
update_current_pingroup_masks();
/* Gear shift is in progress */
if (!gearshift_in_progress())
if (stop_spindle && !spindle_stopped)
stop_spindle = false;
/* determine and update current spindle speed information */
pair_t *speed = get_current_gear(g_tree_mask);
if (speed != NULL)
spindle_speed_out = (float)speed->key;
if (g_last_spindle_speed == spindle_speed_in_abs)
/* Nothing to do */
spindle_at_speed = !spindle_stopped;
return;
/* We need to quantize the requested speed to see if our current
* gear already matches it */
pair_t *new_gear = select_gear_from_rpm(g_tree_rpm,
spindle_speed_in_abs);
/* Current speed already matches the requested speed, nothing to do */
if (new_gear->key == spindle_speed_out)
return;
/* We don't attempt to do anything if the spindle is running. */
/* TODO: check that spindle_stopped triggers only when the spindle
* has come to a full stop and not just a that time it has been
* powered off (might still be moving due to inertia) */
if (!spindle_stopped)
gearshift_stop_spindle();
return;
/* We need to change to another gear */
/* This call will set the start_gear_shift pin! */
gearshift_start(new_gear, period);
/* Do the rest in the next cycle */
return;
/* Do the gear shifting */
gearshift_handle(period);
license "GPL";
/* control pins */
function _;
* need */
FUNCTION(setup)
int i;
temp.value = i;
temp.value = i;
"detected!\n");
* this e-stop */
estop_out = false;
FUNCTION(_)
if (estop_in)
return;
if (!g_setup_done)
if (speed != NULL)
/* Nothing to do */
return;
return;
return;
return;
2 years 3 months ago #304263
Ok, I guess these maybe get used in 'FP4_gears.c', but I'm really out of my depth here. Do you have 'FP4_gearbox.comp' installed and all the other .c and .h files in your system? I'm not even sure where you would need to put those, the 'components' folder would be my guess.
/* Functions related to gear switching. */
#include "FP4_twitch.h"
typedef enum
SHAFT_STATE_OFF, /* Initial shaft state */
SHAFT_STATE_ON, /* Shift in process (i.e. shaft motor running) */
SHAFT_STATE_RESTART /* Error condition, we missed our target and reached
an end point, we need to go back */
} shaft_state_t;
/* Group all data that is required to operate on one shaft */
typedef struct
shaft_state_t state;
pin_group_t status_pins;
hal_bit_t *motor_on;
hal_bit_t *motor_reverse;
hal_bit_t *motor_slow;
unsigned char current_mask; /* auto updated via global variable */
unsigned char target_mask;
} shaft_data_t;
/* Group all data required for gearshifting */
static struct
hal_bit_t *start_shift;
hal_bit_t *do_stop_spindle;
hal_bit_t *is_spindle_stopped;
hal_bit_t *trigger_estop;
hal_bit_t *notify_spindle_at_speed;
bool spindle_on_before_shift;
shaft_data_t vorgelege;
shaft_data_t block2;
shaft_data_t block1;
long delay;
statefunc next;
} g_gearbox_data;
/* One time setup function to prepare data structures related to gearbox
* switching*/
FUNCTION(gearbox_setup)
/* Populate data structures that will be used be the state functions
* when shifting gears */
g_gearbox_data.vorgelege.state = SHAFT_STATE_OFF;
/* Grabbing the pin pointers in EXTRA_SETUP did not work because the
* component did not seem to be fully initializedt there.
* Another issue:
* while output pins are defined as (*__comp_inst->pin_name) by
* halcompile, input pins are turned into (0+*__comp_inst->pin_name)
* which makes it impossible to get the pointers via the defines
* created by halcompile. Accessing the pin variable directly did not
* work due to macro expansion, only workaround I found was to temporarily
* disable the macros.
#pragma push_macro("vorgelege_vorne")
#pragma push_macro("vorgelege_mitte")
#pragma push_macro("vorgelege_hinten")
#pragma push_macro("vorgelege_vorne_hinten")
#undef vorgelege_vorne
#undef vorgelege_mitte
#undef vorgelege_hinten
#undef vorgelege_vorne_hinten
g_gearbox_data.vorgelege.status_pins = (pin_group_t)
__comp_inst->vorgelege_vorne,
__comp_inst->vorgelege_mitte,
__comp_inst->vorgelege_hinten,
#pragma pop_macro("vorgelege_vorne")
#pragma pop_macro("vorgelege_mitte")
#pragma pop_macro("vorgelege_hinten")
#pragma pop_macro("vorgelege_vorne_hinten")
g_gearbox_data.vorgelege.motor_on = &vorgelege_motor;
g_gearbox_data.vorgelege.motor_reverse = &rueckziehen;
g_gearbox_data.vorgelege.motor_slow = &motor_lowspeed;
g_gearbox_data.vorgelege.current_mask = 0;
g_gearbox_data.vorgelege.target_mask =
FP4_gears[FP4_NEUTRAL_GEAR_INDEX].value; /* neutral */
g_gearbox_data.block2.state = SHAFT_STATE_OFF;
#pragma push_macro("block2_vorne")
#pragma push_macro("block2_mitte")
#pragma push_macro("block2_hinten")
#pragma push_macro("block2_vorne_hinten")
#undef block2_vorne
#undef block2_mitte
#undef block2_hinten
#undef block2_vorne_hinten
g_gearbox_data.block2.status_pins = (pin_group_t)
__comp_inst->block2_vorne,
__comp_inst->block2_mitte,
__comp_inst->block2_hinten,
#pragma pop_macro("block2_vorne")
#pragma pop_macro("block2_mitte")
#pragma pop_macro("block2_hinten")
#pragma pop_macro("block2_vorne_hinten")
g_gearbox_data.block2.motor_on = &block2_motor;
g_gearbox_data.block2.motor_reverse = &rueckziehen;
g_gearbox_data.block2.motor_slow = &motor_lowspeed;
g_gearbox_data.block2.current_mask = 0;
g_gearbox_data.block2.target_mask = 0; /* don't care for neutral */
g_gearbox_data.block1.state = SHAFT_STATE_OFF;
#pragma push_macro("block1_vorne")
#pragma push_macro("block1_mitte")
#pragma push_macro("block1_hinten")
#pragma push_macro("block1_vorne_hinten")
#undef block1_vorne
#undef block1_mitte
#undef block1_hinten
#undef block1_vorne_hinten
g_gearbox_data.block1.status_pins = (pin_group_t)
__comp_inst->block1_vorne,
__comp_inst->block1_mitte,
__comp_inst->block1_hinten,
#pragma pop_macro("block1_vorne")
#pragma pop_macro("block1_mitte")
#pragma pop_macro("block1_hinten")
#pragma pop_macro("block1_vorne_hinten")
g_gearbox_data.block1.motor_on = &block1_motor;
g_gearbox_data.block1.motor_reverse = &rueckziehen;
g_gearbox_data.block1.motor_slow = &motor_lowspeed;
g_gearbox_data.block1.current_mask = 0;
g_gearbox_data.block1.target_mask = 0; /* don't care for neutral */
#pragma push_macro("spindle_stopped")
#undef spindle_stopped
#pragma pop_macro("spindle_stopped")
g_gearbox_data.do_stop_spindle = &stop_spindle;
g_gearbox_data.spindle_on_before_shift = false;
g_gearbox_data.trigger_estop = &estop_out;
g_gearbox_data.notify_spindle_at_speed = &spindle_at_speed;
g_gearbox_data.delay = 0;
g_gearbox_data.next = NULL;
static void gearshift_stop_spindle(void)
!(*g_gearbox_data.is_spindle_stopped);
*g_gearbox_data.do_stop_spindle = true;
/* combine values of all pins in a group to a bitmask */
static unsigned char get_bitmask_from_pingroup(pin_group_t *group)
unsigned char mask = 0;
int i;
for (i = 0; i < FP4_PINS_IN_GROUP; i++)
mask |= *(group->p) << i;
return mask;
/* Update current mask values for each shaft */
static void update_current_pingroup_masks(void)
get_bitmask_from_pingroup(&g_gearbox_data.vorgelege.status_pins);
get_bitmask_from_pingroup(&g_gearbox_data.block2.status_pins);
get_bitmask_from_pingroup(&g_gearbox_data.block1.status_pins);
static bool estop_on_spindle_running(void)
if (!*g_gearbox_data.is_spindle_stopped)
/* This is an invalid condition, spindle must be stopped if we are
* shifting and we tested for it before we started.
* We expect that estop_out will be looped back to us so that
* it will trigger our handler. */
rtapi_print_msg(RTAPI_MSG_ERR, "FP4_gearbox FATAL ERROR: detected "
"running spindle while shifting, triggering emergency stop!\n");
*g_gearbox_data.trigger_estop = true;
return true;
return false;
/* Combine masks from each pin group to a value representing the current
* gear setting. A return of NULL means that a corresponding value could
* not be found, which may indicate a gearshift being in progress- */
static pair_t* get_current_gear(tree_node_t *tree)
tree_node_t *result;
unsigned combined = (g_gearbox_data.block1.current_mask <<
(g_gearbox_data.block2.current_mask << 4) |
g_gearbox_data.vorgelege.current_mask;
/* special case: ignore all other bits for neutral */
if (g_gearbox_data.vorgelege.current_mask ==
FP4_gears[FP4_NEUTRAL_GEAR_INDEX].value)
return &(FP4_gears[FP4_NEUTRAL_GEAR_INDEX]);
result = tree_search(tree, combined);
if (result != NULL)
return &(FP4_gears[result->value]);
return NULL;
/* Helper to update delays, returns true if time has not elapsed. */
static bool gearshift_wait_delay(long period)
if ((period > 0) && (g_gearbox_data.delay > 0))
g_gearbox_data.delay = g_gearbox_data.delay - period;
return true;
return false;
/* From:
* forum.linuxcnc.org/12-milling/33035-retr...FP4?start=460#117021
* 1. if u need to go to the vorne then turn cw
* 2. if u need to go to the mitte than turn ccw
* 3. if u need to go to the block2 and vorne-hinten is 1 then turn ccw else cw
* ┘ └──────────────── vorne
* ────────┘ └──────── hinten
* ────────────────┘ └ mitte
* ──────────┘ vorne-hinten
static bool gearshift_need_reverse(unsigned char target_mask,
unsigned char current_mask)
if (FP4_STAGE_IS_mitte(target_mask)) /* CCW, reverse is on */
return true;
else if (FP4_STAGE_IS_vorne(target_mask)) /* CW, reverse is off */
return false;
else if (FP4_STAGE_IS_hinten(target_mask))
return false;
return true;
/* State functions */
/* This is more or less an "overshoot" protection check in case we missed the
* target hinten pos and moved further. We know when we reach an end point
* and we know we can't continue further in this direction, so stop trying and
* go back. Returns true if action needs to be taken. */
static bool gearshift_protect(shaft_data_t *shaft)
if (!*shaft->motor_on)
return false;
if (*shaft->motor_reverse)
/* If we move to the vorne/CW and we reached the furthest vorne position
* which does not seem to be our desired target, then we should
* disable the motor and trigger an E-STOP, we should never end up#
* in this situation. */
if ((shaft->current_mask == FP4_STAGE_POS_mitte) &&
(shaft->current_mask != shaft->target_mask))
rtapi_print_msg(RTAPI_MSG_ERR, "FP4_gearbox: WARNING: "
"shaft motor at unexpected mitte position!\n");
else
return false;
else
if ((shaft->current_mask == FP4_STAGE_POS_vorne) &&
"shaft motor at unexpected vorne position!\n");
else
return false;
return true;
/* Generic function that has the exact same logic, valid for all of the
* three shafts. */
static void gearshift_stage(shaft_data_t *shaft, statefunc me, statefunc next,
long period)
if (estop_on_spindle_running())
return;
if (gearshift_wait_delay(period))
g_gearbox_data.next = me;
return;
if (shaft->state == SHAFT_STATE_OFF)
/* Are the pins already in the desired state? */
if (shaft->current_mask == shaft->target_mask)
g_gearbox_data.next = next;
else
shaft->state = SHAFT_STATE_ON;
if (gearshift_need_reverse(shaft->target_mask,
shaft->current_mask))
*shaft->motor_reverse = true;
g_gearbox_data.delay = FP4_REVERSE_MOTOR_INTERVAL;
else if (shaft->state == SHAFT_STATE_ON)
/* Did we reach the desired position? */
if (*shaft->motor_on)
/* De-energize the shaft motor */
*shaft->motor_on = false;
else
/* Second time we enter this state the motor will be off,
* that means that we already did the waiting that may have
* been set in the "if" below. If reverse direction was
* not active originally, then this does nothing */
*shaft->motor_reverse = false;
/* If reverse direction has been set, disable it in 100ms */
g_gearbox_data.delay = FP4_GENERIC_PIN_INTERVAL;
return;
else
*shaft->motor_slow = false;
if (*shaft->motor_slow)
return;
/* We are done here, proceed to the next stage */
shaft->state = SHAFT_STATE_OFF;
else
/* Protect furthest lect/CW and mitte/CCW end positions by not
* allowing the motor to continue running if we reached them,
* this should never happen, but it's better to have a safety
* measure to prevent hardware damage. The function will
* immediately stop the motor and trigger an emergency stop if this
* error condition is detected. */
if (gearshift_protect(shaft))
shaft->state = SHAFT_STATE_RESTART;
return;
/* Going to the hinten requres lowering the motor speed */
if (FP4_STAGE_IS_hinten(shaft->target_mask) &&
!(*shaft->motor_slow))
*shaft->motor_slow = true;
else if (!(*shaft->motor_on))
/* Energize motor if it is not yet running */
*shaft->motor_on = true;
g_gearbox_data.delay = FP4_GEAR_STAGE_POLL_INTERVAL;
else if (shaft->state == SHAFT_STATE_RESTART)
/* Protection function restarted us, motor is already off and
* we came here after a certain delay. We now need to check what to do
* and re-energize */
return;
/* Going back to the OFF state will retrigger the shift logic for
* this shaft */
static void gearshift_stop(long period)
g_gearbox_data.next = gearshift_stop;
return;
twitch_stop(period);
if (!twitch_stop_completed())
g_gearbox_data.delay = FP4_TWITCH_KEEP_PIN_OFF;
return;
if (*g_gearbox_data.start_shift)
if (g_gearbox_data.spindle_on_before_shift)
*g_gearbox_data.do_stop_spindle = false;
g_gearbox_data.delay = FP4_WAIT_SPINDLE_AT_SPEED;
return;
*g_gearbox_data.notify_spindle_at_speed = true;
/* We are done shifting, reset everything */
static void gearshift_vorgelege(long period)
gearshift_stage(&(g_gearbox_data.vorgelege), gearshift_vorgelege,
gearshift_stop, period);
static void gearshift_block2(long period)
gearshift_stage(&(g_gearbox_data.block2), gearshift_block2,
gearshift_vorgelege, period);
static void gearshift_block1(long period)
gearshift_stage(&(g_gearbox_data.block1), gearshift_block1,
gearshift_block2, period);
/* Call this function once per each thread cycle to handle gearshifting,
* implies that gearshift_start() has been called in order to set the
* target gear. */
static void gearshift_handle(long period)
twitch_handle(period);
if (g_gearbox_data.next == NULL)
rtapi_print_msg(RTAPI_MSG_ERR, "FP4_gearbox FATAL ERROR: "
"gearshift function not set up, triggering E-Stop!\n");
return;
g_gearbox_data.next(period);
/* Start shifting process */
static void gearshift_start(pair_t *target_gear, long period)
return;
g_gearbox_data.vorgelege.target_mask = (target_gear->value) & 0x000f;
g_gearbox_data.block2.target_mask = (target_gear->value & 0x00f0) >> 4;
(target_gear->value & 0x0f00) >> 8;
/* Make sure to leave 100ms between setting start_gear_shift to "on"
* and further operations */
twitch_start(period);
/* Special case: if we want to go to the neutral position, we
* only care about the vorgelege stage, so we can jump mitte to it */
if (g_gearbox_data.vorgelege.target_mask ==
FP4_gears[FP4_NEUTRAL_GEAR_INDEX].value) {
g_gearbox_data.next = gearshift_vorgelege;
else
g_gearbox_data.next = gearshift_block1;
/* Reset pins and state machine if an emergency stop was triggered. */
static void gearbox_handle_estop(void)
*g_gearbox_data.block1.motor_on = false;
*g_gearbox_data.block2.motor_on = false;
*g_gearbox_data.vorgelege.motor_on = false;
/* There are no separate pins for revers/slow for each shaft, each
* shaft structure has pointers to the same pins, so its enough to
* reset them only on one shaft. */
*g_gearbox_data.vorgelege.motor_reverse = false;
*g_gearbox_data.vorgelege.motor_slow = false;
gearshift_stop(0); /* Will stop and reset twitching as well */
static bool gearshift_in_progress(void)
return g_gearbox_data.next != NULL;
Warning: Spoiler!
typedef enum
} shaft_state_t;
typedef struct
} shaft_data_t;
static struct
long delay;
statefunc next;
} g_gearbox_data;
* switching*/
* Another issue:
#undef block2_vorne
#undef block2_mitte
#undef block1_vorne
#undef block1_mitte
int i;
return mask;
return true;
return false;
if (result != NULL)
return NULL;
return true;
return false;
/* From:
return true;
return false;
return false;
return true;
return false;
else
return false;
else
else
return false;
return true;
* three shafts. */
long period)
return;
return;
else
else
return;
else
return;
else
return;
return;
* this shaft */
return;
return;
return;
* target gear. */
return;
return;
else
- Walkahz
- Thank you received: 7
2 years 3 months ago #304293
by Walkahz
Replied by Walkahz on topic Deckel FP4 Gearbox Comp
Comp is installed. .C and .H files are in the same location as the HAL. unsure if i need to save into where the comp installs. I couldnt use the makefile that was in the original code to install it all.
2 years 3 months ago #304298
Have you tried starting your config from the terminal to check for error messages in the output?
$ linuxcnc
$ linuxcnc
- Walkahz
2 years 3 months ago #304526
by Walkahz
Not sure exactly how to open in comp.
Ive made a little progress.
I abandoned the modified Files I was using and went back to mark's files as downloaded from github.
i then have gone through to modify as required to remove the unneeded portions.
I was able to compile it and stopped getting the errors above when I uncomment the inputs and outputs, So the Hal is talking to the comp.
Still having a few problems but at least they are different. I was able to open LCNC but it opened very slow and showed a different version to what i have installed (2.4 rather than the 2.9 i have installed)
After some changes to the hal to try to identify the issue I was then once again unable to open LCNC and had the following debug information come up.
2 steps forward 1 back.
Debug file information: Note: Using POSIX realtime rtapi_app: caught signal 11 - dumping core [Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532) [Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532) [Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532) [Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532) [Gmoccapy.QTVCP.QT_ISTAT][[33mWARNING[0m] INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532) (gmoccapy:25734): Gtk-CRITICAL **: 06:32:40.415: gtk_entry_set_text: assertion 'text != NULL' failed [Gmoccapy.GMOCCAPY.GETINIINFO][[33mWARNING[0m] No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file (getiniinfo.py:282) Waiting for component 'inihal' to become ready. While waiting for 'inihal', component 'gmoccapy' loaded. Did you specify the correct name via 'loadusr -Wn'?.........................................................................................................................................................................................HAL: ERROR: exit called before init :0: waitpid failed milltask inihal :0: milltask exited without becoming ready [Gmoccapy][[33mWARNING[0m] No virtual keyboard installed, we checked for . Try 'sudo apt-get install onboard'. (gmoccapy:2080) Could not open command file 'gmoccapy_postgui.hal' 25678 Stopping realtime threads Unloading hal components Waited 3 seconds for master. giving up. Note: Using POSIX realtime mh400e_gearbox: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime mux16: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime classicladder_rt: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime pid: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime hm2_eth: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime hostmot2: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime motmod: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime trivkins: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime homemod: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 Note: Using POSIX realtime tpmod: not loaded :0: exit value: 255 :0: rmmod failed, returned -1 :0: unloadrt failed Note: Using POSIX realtime
- Walkahz
2 years 3 months ago #304655
by Walkahz
Solved the boot issue.
Seems to be an issue with the line
Addf mh400e-gearbox. Servo-thread
Once I removed this from HAL I could boot normally again.
I attached the screen that was showing when it was bugging. See attached
Time to create page: 0.704 seconds
