Mesa 7i96s firmware for Index (2.9 release)
- Thank you received: 5335
01 Dec 2024 02:30 #315700
Replied by PCW on topic Mesa 7i96s firmware for Index (2.9 release)
It connects to the hardware stepgen index pin
probably something like:
hm2_7i96s.0.stepgen.00.index-enable
halcmd show pin hm2 | grep index
(when linuxcnc is running)
should list it
should list it
- vibram
01 Dec 2024 08:51 #315716
by vibram
Replied by vibram on topic Mesa 7i96s firmware for Index (2.9 release)
Here is the output of the command:
38 bit I/O FALSE hm2_7i96s.0.7i73.0.0.enc0.index-enable
38 bit I/O FALSE hm2_7i96s.0.7i73.0.0.enc1.index-enable
38 bit I/O FALSE hm2_7i96s.0.7i73.0.0.enc2.index-enable
38 bit I/O FALSE hm2_7i96s.0.7i73.0.0.enc3.index-enable
38 bit I/O FALSE hm2_7i96s.0.encoder.00.index-enable <=> spindle-index-enable
38 bit OUT FALSE hm2_7i96s.0.encoder.00.input-index
38 bit I/O FALSE hm2_7i96s.0.stepgen.00.index-enable
38 bit IN FALSE hm2_7i96s.0.stepgen.00.index-invert
38 bit I/O FALSE hm2_7i96s.0.stepgen.01.index-enable
38 bit IN FALSE hm2_7i96s.0.stepgen.01.index-invert
and the end of my readhmid
O Connections for P1 -> 7I96_2
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
P1-01/DB25-01 34 IOPort StepGen 0 Index (In)
P1-02/DB25-14 35 IOPort StepGen 1 Index (In)
P1-03/DB25-02 36 IOPort StepGen 2 Index (In)
P1-04/DB25-15 37 IOPort StepGen 3 Index (In)
P1-05/DB25-03 38 IOPort StepGen 4 Index (In)
I connected normal input on IO 34 qnd 35, it works fine. But how should I tell the system the stepgen index for axis X is on the 36 and for the axis z on the 37 ?
01 Dec 2024 14:43 - 01 Dec 2024 16:57 #315734
You cannot, the index mapping is fixed by the firmware. That is, GPIO 34 is always the index for stepgen 00,
GPIO 35 is the index for stepgen 01 etc. You can, however map any stepgen to any axis.
Last edit: 01 Dec 2024 16:57 by PCW.
- rickjmain
14 Apr 2025 21:41 #326319
by rickjmain
Replied by rickjmain on topic Mesa 7i96s firmware for Index (2.9 release)
Hi PCW, I'm still fairly early in my latest build, just testing things out. I've flashed over the firmware, and it shows the Index function on GPIO 34-38. I've also made an adapter cable with 220 ohm resistors. I can see the GPIO pins change in halshow when i connect them to ground but the hm2_7i96s.0.stepgen.xx.index-enable pin doesn't change. Should I be linking like so:
net x-index-enable <= hm2_7i96s.0.gpio.034.in
net x-index-enable => joint.0.index-enable
or like this:
net x-index-enable <= hm2_7i96s.0.stepgen.00.index-enable
Thanks for your help on this!
or like this:
14 Apr 2025 23:34 #326325
Would be correct.
To test: (with linuxcnc running and watching x-index-enable with halshow)
halcmd -kf
halcmd: sets x-index-enable
(this should set x-index-enable true)
Then toggle the index input
(that should set x-index-enable false)
Would be correct.
halcmd -kf
The following user(s) said Thank You: rickjmain
- rickjmain
14 Apr 2025 23:53 #326326
by rickjmain
That worked perfectly, thanks!
Time to create page: 0.392 seconds
