- Thank you received: 907
Took a different work around / approach. Instead of requiring my customers to set a max expected feedrate in their G-code, my new feedback control will require them to always set the feedrate to F1000. This is then the highest feedrate used for retractions. My feed control component then does the scaling stuff and estimating the optimal FRO value. This works nicely.
I did run into show stopper performance issues after switching to 2.9.3 and bookworm, I'll start a new topic for that.
As best I recall, I was preserving the existing behavior (it was likely limited to [0,1.0] before). That said, I don't think there's a fundamental reason it can't be greater than 1, though you'll get suboptimal lookahead behavior if you make it greater than the max feed scale value defined in the INI file. The TP creates the blend arcs with large enough radii to be smooth at maximum feed override. If you made the valid range [-max feed scale, max feed scale], I think it would be safe.
