- Thank you received: 907
I am using the motion.adaptive-feed to control my feedrate. The linuxcnc manual states:
"When adaptive feed is enabled with M52 P1, the commanded velocity is multiplied by this value. This effect is multiplicative with the NML-level feed override value and motion.feed-hold. Negative values are valid and will run the G-code path in reverse."
While trying this out, it only seems to work for the range -1...1 any values above or below that are clipped to 1 or -1.
I need to be able to set the value to greater than -1, e.g. -10 or greater. Is this possible and how can that be done?
