So I'm adding a Tsudokama RZ-160 rotary as a full 4th axis. I'm replacing the existing TPC-JR with a standalone drive and wiring everything direct. I have a good handle on most of this, however I'm left with the choice in the title. The encoder is an absolute encoder wired directly to the drive. The drive then either passes along the serial absolute position OR has outputs for a simulated incremental encoder. I know how to wire the incremental, it's the same as my other 3 axes, and can get wired directly into "Axis 3" on the 7i77 board. However, the RZ-160 of course does not have homing switches (that I'm aware of), so repeating the same location with the incremental encoder output through a power cycle may prove challenging. At the very least, I'd have to break out an indicator and indicate in the 4th if I understand correctly. With the Absolute encoder, in theory, I'll always know where the rotary table is at. I don't know that that is accurate, and it may only remember location within 1 rotation of the motor, which is 1/60th a rotation of the table. Is that accurate? Can the PSO /PSO output be wired into the 7i77 SSerial port easily? Is it worth it?How would you set up your 4th axis given this choice? My drive is a Sigma II Yaskawa drive (SGDM-04ADA, same as what is in the TPC-JR), the servo is a Sigma II (SGMPH-04A1A-TF11).
Thank you
