- Configuring LinuxCNC
- Advanced Configuration
- unable to get gpio to work on Raspberry Pi 5 using latest image
- galrub
05 Feb 2025 21:33 #320796
by galrub
unable to get gpio to work on Raspberry Pi 5 using latest image was created by galrub
Hello I am using the latgest build, rpi-5-debian-bookworm-6.12.11-arm64-ext4-2025-01-27-0140.img, on a RP 5, logged in with user 'cnc'
runing:
any ideas?
I notice some disccusions about this matter in the forum but non of the ideas there helped me,
I tried 'sudo gpasswd -a cnc gpio' but got the reply that cnc is already a member of gpio.
any help will be most welcomed.
runing:
uname -a
Linux raspberrypi 6.12.11 #1 SMP PREEMPT_RT Mon Jan 27 00:10:15 AEDT 2025 aarch64 GNU/Linux
halcmd -I
loadrt hal_gpio inputs=GPIO18,GPIO23,GPIO24,GPIO25,GPIO8 outputs=GPIO4,GPIO17,GPIO27,GPIO22,GPIO10,GPIO9,GPIO26
Note: Using POSIX realtime
hal_gpio: Failed to register input pin collection
hal_gpio: rtapi_app_main: Operation not permitted (-1)
<stdin>:1: waitpid failed /usr/bin/rtapi_app hal_gpio
<stdin>:1: /usr/bin/rtapi_app exited without becoming ready
<stdin>:1: insmod for hal_gpio failed, returned -1
loadrt hal_pi_gpio exclude=0xC3C03 dir=0x312839C
The Pi model 23 is not known to work with this driver but will be assumed to be be using the RPi2+ layout 40 pin connector
HAL_PI_GPIO: can't open /dev/gpiomem: 2 - No such file or directory
If the error is 'permission denied' then try adding the user who runs
LinuxCNC to the gpio group: sudo gpasswd -a username gpio
HAL_PI_GPIO: can't open /dev/mem: 13 - Permission denied
hal_pi_gpio: rtapi_app_main: Operation not permitted (-1)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hal_pi_gpio
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hal_pi_gpio failed, returned -1any ideas?
09 Feb 2025 18:44 #321090
Replied by andypugh on topic unable to get gpio to work on Raspberry Pi 5 using latest image
It is possible that hal_gpio is not working because libgpiod is not installed
What does: sudo apt-get install libgpiod say?
- unknown
- Thank you received: 323
09 Feb 2025 23:02 - 09 Feb 2025 23:19 #321128
by unknown
Replied by unknown on topic unable to get gpio to work on Raspberry Pi 5 using latest image
It does work, 2 users have had a couple of users have confirmed it.
I've also confirmed myself that loading of the driver as given in the docs also works.
Taking GPIO8 out of the input list allows the driver to load correctly. Which makes sense as GPIO08 as well as GPIO07 seemed to be claimed.
section lifted from gpioinfo
"GPIO7" "spi0 CS1" output active-low [used]
"GPIO8" "spi0 CS0" output active-low [used]
Commenting out spi out in /boot/broadcom/config.txt "fixes" the issue.
halcmd: loadrt hal_gpio inputs=GPIO18,GPIO23,GPIO24,GPIO25,GPIO8 outputs=GPIO4,GPIO17,GPIO27,GPIO22,GPIO10,GPIO9,GPIO26
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
4 bit IN FALSE hal_gpio.GPIO10-out
4 bit IN FALSE hal_gpio.GPIO17-out
4 bit OUT FALSE hal_gpio.GPIO18-in
4 bit OUT FALSE hal_gpio.GPIO18-in-not
4 bit IN FALSE hal_gpio.GPIO22-out
4 bit OUT FALSE hal_gpio.GPIO23-in
4 bit OUT FALSE hal_gpio.GPIO23-in-not
4 bit OUT FALSE hal_gpio.GPIO24-in
4 bit OUT FALSE hal_gpio.GPIO24-in-not
4 bit OUT FALSE hal_gpio.GPIO25-in
4 bit OUT FALSE hal_gpio.GPIO25-in-not
4 bit IN FALSE hal_gpio.GPIO26-out
4 bit IN FALSE hal_gpio.GPIO27-out
4 bit IN FALSE hal_gpio.GPIO4-out
4 bit OUT FALSE hal_gpio.GPIO8-in
4 bit OUT FALSE hal_gpio.GPIO8-in-not
4 bit IN FALSE hal_gpio.GPIO9-out
4 s32 OUT 0 hal_gpio.read.time
4 s32 OUT 0 hal_gpio.write.time
Last edit: 09 Feb 2025 23:19 by unknown.
- mikereid0817
26 Apr 2025 02:26 #327071
by mikereid0817
Replied by mikereid0817 on topic unable to get gpio to work on Raspberry Pi 5 using latest image
Hi, I got my latest image working. In /boot/broadcom under config.txt, you need to comment out the line that enables SPI: dtparam=spi=on -> #dtparam=spi=on.
Then you can use GPIO7 and GPIO8.
You do not need to load hal_pi_gpio, it doesn't work on PI5.
The good news is that you don't need it, either.
- Grad
04 May 2025 17:37 #327694
by Grad
Replied by Grad on topic unable to get gpio to work on Raspberry Pi 5 using latest image
Hi, i have a similar problem with my RPi5 and GPIO but I think I/(the AI that helped me) screwed up with the .hal-File. Do you (or anyone) mind to put your working .hal here so I can see how it is done?
- unknown
04 May 2025 18:21 #327699
by unknown
forum.linuxcnc.org/9-installing-linuxcnc...only?start=10#321296
WTF would you use AI ?????????
BTW Just about everything to do with the Rpi5\4 images is in the thread linked above, rather than waste time with AI read something, a lot of work has and is going into that thread.
The following user(s) said Thank You: Grad
- Grad
04 May 2025 19:14 #327701
by Grad
Well, that thread helped me before but i somehow did not notice the "Basic Mill Config Using hal_gpio" ...would have saved me a lot of time... anyways - works fine now - Thank you!
- mikereid0817
20 May 2025 01:26 #328770
by mikereid0817
Hi Andy... I am muddling my way through this and have things working really well, except inputs. Gpio reads gpio13 fine in python, hal_gpio always shows high in hal scope, meter etc. Any ideas? Is there a way to set gpio characteristics with hal?
- unknown
20 May 2025 02:23 #328773
by unknown
If you want help, you will have to upload your hal & ini files, otherwise no one knows exactly what you are doing.
20 May 2025 11:27 #328796
opendrain
opensource
biasdisable
pulldown
pullup
As described in linuxcnc.org/docs/devel/html/drivers/hal_gpio.html#_usage
I am not clear if you are saying that it is always set and the input can not be changed, even if pulled low?
Have you checked with gpioinfo that nothing is claiming the pin?
You can try setting the various modifiers for GPIO13 and see if that helps.Hi Andy... I am muddling my way through this and have things working really well, except inputs. Gpio reads gpio13 fine in python, hal_gpio always shows high in hal scope, meter etc. Any ideas? Is there a way to set gpio characteristics with hal?
opendrain
opensource
biasdisable
pulldown
pullup
Time to create page: 0.219 seconds
