- Thank you received: 241
( My sequence of Running; )
( 1. Use a T99, a .250" Rod, to touch off X, Y, and Z of WCS as modeled in CAM )
( 2. Manually input M600 ) or just enter #<_ToolDidFirst> = 0 in MDI
( 3. Manually call an M6 T99, tool will touch off on toolsetter and store tool height )
( 4. Load program and run, M6 in program will prompt tool change, after changing, tool will touch off and Z will adjust )
( 5. Run any and all code using the same desired Z height for the WCS as designed )
( 6. For new WCS repeat from Step #1 )
