I made a lot of work on the tool setter/probe, here is the latest version which is working fine with gmoccapy :
O<change> sub
;(debug, in change tool_in_spindle=#<tool_in_spindle> current_pocket=#<current_pocket>;)
;(debug, selected_tool=#<selected_tool> selected_pocket=#<selected_pocket>;)
;(debug, current tool z_offset=#5403)
;otherwise after the M6 this information is gone!
#<xpos> = #<_x> (PRINT,save absolute X=#<_x>;)
#<ypos> = #<_y> (PRINT,save absolute Y=#<_y>;)
#<tlo> = #5403 (PRINT,current offset for tool #<_selected_tool>=#<tlo>;)
#<cht> = #<_ini[CHANGE_POSITION]TRAVELZ>
#<chx> = #<_ini[CHANGE_POSITION]X>
#<chy> = #<_ini[CHANGE_POSITION]Y>
#<chz> = #<_ini[CHANGE_POSITION]Z>
#<tsm> = #<_ini[TOOLSENSOR]MAXPROBE>
#<tsx> = #<_ini[TOOLSENSOR]X>
#<tsy> = #<_ini[TOOLSENSOR]Y>
#<tsz> = #<_ini[TOOLSENSOR]Z>
; we must execute this only in the milltask interpreter
; or preview will break, so test for '#<_task>' which is 1 for
; the milltask interpreter and 0 in the UI's
O100 if [#<_task> EQ 0]
O100 return [999]
O100 endif
O200 if [#<_hal[gmoccapy.toolmeasurement]> EQ 0]
O200 return [3] ; indicate no tool measurement
O200 endif
O300 if [#<_hal[gmoccapy.searchvel]> LE 0]
O300 return [-1] ; indicate searchvel <= 0
O300 endif
O400 if [#<_hal[gmoccapy.probevel]> LE 0]
O400 return [-2] ; indicate probevel <= 0
O400 endif
G53 G0 Z[#<cht>] (PRINT,move to travel height)
G53 G0 X[#<chx>] Y[#<chy>] (PRINT,move to change position)
G53 G0 Z[#<chz>]
G49 (PRINT,cancel tool offset)
G92.2 (PRINT,turn off G92 offsets)
M6 (PRINT,real change tool)
O700 if [#<_selected_tool> EQ 99]
G10 L1 P99 Z0 (PRINT,reset probe offset)
O700 else
G53 G0 X[#<tsx>] Y[#<tsy>] (PRINT,move to toolsensor)
G53 G0 Z[#<tsz>]
F #<_hal[gmoccapy.searchvel]> (PRINT,set search speed)
G91 (PRINT,relative move )
G38.2 Z#<tsm> (PRINT,touch sensor)
G0 Z2 (PRINT,release sensor)
F #<_hal[gmoccapy.probevel]> (PRINT,set probe speed)
G38.2 Z-4 (PRINT,touch sensor)
G90 (PRINT,absolute move)
O800 if [#5070 EQ 0]
O800 return [-3] ; indicate probe contact failure to epilog
O800 endif
G10 L10 P[#<_selected_tool>] Z[#4963] (PRINT,set absolute offset for tool #<_selected_tool>;)
G43
O700 endif
G92.3 (PRINT,restore G92 offsets)
G0 X[#<xpos>] Y[#<ypos>] (PRINT,return to where we were in WCS X=#<xpos> Y=#<ypos>;)
; signal success be returning a value > 0:
O<change> endsub [1]
M2
O<init_probe> SUB
(PRINT,Probe init)
G94 (PRINT,use feedrate in units/min )
G92.1 (PRINT,remove G92 offsets)
G90 (PRINT,absolute distance mode)
G49 (PRINT,cancel tool length compensation)
G40 (PRINT,turn cutter compensation off)
G10 L2 P0 X0 Y0 Z0 (PRINT,reset coordinate system)
O100 IF [ #<_current_tool> NE 99 ] (PRINT,tool loaded: #<_current_tool>;)
T99 M6 (PRINT,mount probe)
O100 ENDIF
O101 IF [ #<_metric> EQ 1 ] (PRINT,set probe feeds according to units )
#<fast> = 150.0 (PRINT,selected metric units )
#<slow> = 30.0
#<retract> = 3.0
#<tool_diam> = #5410 (PRINT,tool diameter=#<tool_diam>mm)
O101 ELSE
#<fast> = 6.0 (PRINT,selected imperial units )
#<slow> = 1.2
#<retract> = 0.1
#<tool_diam> = #5410 (PRINT,tool diameter=#<tool_diam>in)
O101 ENDIF
(PRINT,touch plate Z probe)
G38.2 Z[#<_ini[AXIS_Z]MIN_LIMIT>] F[#<fast>] (PRINT,Z probe toward workpiece with error )
G0 Z[#<retract>] (PRINT,retract)
G0 Z-[#<retract>/2] (PRINT,move forward half retract distance)
G38.2 Z-[#<retract>] F[#<slow>] (PRINT,Z probe slowly, got Z probe at #5063)
G10 L20 P0 Z[#<_ini[TOUCHPLATE]OFFSETZ>] (PRINT,set Z offset in current WCS)
G0 Z#<retract> (PRINT,retract)
(PRINT,touch plate X probe)
G0 X-[#<retract> + #<tool_diam>] (PRINT,move in front of touch plate)
G0 Z-[#<retract> * 2] (PRINT,go down by twice retract length)
G38.2 X[#<retract> + #<tool_diam>] F[#<fast>] (PRINT,X probe toward workpiece with error )
G0 X-[#<retract>] (PRINT,retract)
G0 X[#<retract>/2] (PRINT,move forward half retract distance)
G38.2 X[#<retract> + #<tool_diam>] F[#<slow>] (PRINT,X probe slowly, got X probe at #5061)
G10 L20 P0 X-[#<_ini[TOUCHPLATE]OFFSETX> + #<tool_diam> / 2] (PRINT,set X offset in current WCS)
G0 X-[#<retract>] Z[#<retract>*2] (PRINT,retract)
(PRINT,Touch plate Y probe)
G0 X[#<retract> + #<tool_diam>] Y-[#<retract> + #<tool_diam>] (PRINT,move below of touch plate)
G0 Z-[#<retract>*2] (PRINT,go down by twice retract length)
G38.2 Y[#<retract> + #<tool_diam>] F[#<fast>] (PRINT,X probe toward workpiece with error)
G0 Y-[#<retract>] (PRINT,retract)
G0 Y[#<retract>/2] (PRINT,move forward half retract distance)
G38.2 Y[#<retract> + #<tool_diam>] F[#<slow>] (PRINT,Y probe slowly, got Y probe at #5062)
G10 L20 P0 Y-[#<_ini[TOUCHPLATE]OFFSETY> + #<tool_diam> / 2] (PRINT,set Y offset in current WCS)
G0 Y-[#<retract>] Z[#<retract> * 2] (PRINT,retract)
G0 X0 Y0 (PRINT,move to travel height)
G53 G0 Z[#<_ini[CHANGE_POSITION]TRAVELZ>] (PRINT,move to safe travel height)
G53 G0 X[#<_ini[TOOLSENSOR]X>] Y[#<_ini[TOOLSENSOR]Y>] (PRINT,move to toolsensor)
G53 G0 Z[#<_ini[TOOLSENSOR]Z>]
G38.2 Z#<_ini[TOOLSENSOR]MAXPROBE> (PRINT,touch sensor)
#4963 = #5063 (PRINT,store probe trigger Z value)
G53 G0 Z[#<_ini[CHANGE_POSITION]TRAVELZ>] (PRINT,move to travel height)
G53 G0 X[#<_ini[CHANGE_POSITION]X>] Y[#<_ini[CHANGE_POSITION]Y>] (PRINT,move to change position)
G53 G0 Z[#<_ini[CHANGE_POSITION]Z>]
O<init_probe> ENDSUB
M2
